trigeek Posted April 30, 2007 Share Posted April 30, 2007 Hey Folks, Decided to save some coin and change my winter and summer wheels myself. So I'm gonna pick up a torque wrench. But I want to make sure I get a wrench that will torque in the right range. Anyone know the proper torque for the wheels on an '07 spec.B in Canada (I imagine the US is the same). Thanks for the help. Link to comment Share on other sites More sharing options...
Hanger Posted April 30, 2007 Share Posted April 30, 2007 i set my torque wrench at 80lbs ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Flanders Posted May 1, 2007 Share Posted May 1, 2007 I believe the spec is in the manual. Link to comment Share on other sites More sharing options...
trigeek Posted May 2, 2007 Author Share Posted May 2, 2007 I couldn't find it in the manual, I did check. 80lbs sounds to be in the right range. Any other suggestions out there? Anyone know a guy who knows a guy who works at a Subbie dealer? thanks Link to comment Share on other sites More sharing options...
rao Posted May 2, 2007 Share Posted May 2, 2007 It is 81.1 ft.lbs. Trust us, we are not lying to you. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted May 2, 2007 Share Posted May 2, 2007 It is 81.1 ft.lbs. Trust us, we are not lying to you. Are you positive? It is a Spec B afterall???? OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
andrew.anderson Posted May 2, 2007 Share Posted May 2, 2007 I just torque them down with the tire iron then kick the tire iron a few times for each lug nut to make sure they are extra tight. Link to comment Share on other sites More sharing options...
LowFast Posted May 2, 2007 Share Posted May 2, 2007 I just torque them down with the tire iron then kick the tire iron a few times for each lug nut to make sure they are extra tight. Ahh, the scientific method. Link to comment Share on other sites More sharing options...
Hanger Posted May 2, 2007 Share Posted May 2, 2007 hmm got a question for you guys too, i set my torque wrench at 80lbs, before when i tighten the lugs i get them tighten til it makes the click sound. But now i tighten the lugs as tight as i could, but the wrench doesn't make click sound anymore... ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
LowFast Posted May 2, 2007 Share Posted May 2, 2007 Either: A. Broken wrench B. Need to eat your wheaties. Link to comment Share on other sites More sharing options...
pillboy Posted May 2, 2007 Share Posted May 2, 2007 hmm got a question for you guys too, i set my torque wrench at 80lbs, before when i tighten the lugs i get them tighten til it makes the click sound. But now i tighten the lugs as tight as i could, but the wrench doesn't make click sound anymore... You have either become extremely weak or the wrench is broken. Since buying a torque wrench I have been amazed just how little 80 ft lb is. It is still ugly. Link to comment Share on other sites More sharing options...
rabydanimal Posted May 2, 2007 Share Posted May 2, 2007 Do you really need to measure this? I just torque them on as hard as I can by hand then re-check them after a short drive. Every shop I've ever been to has most definitely torqued them well past factory spec. Link to comment Share on other sites More sharing options...
pillboy Posted May 2, 2007 Share Posted May 2, 2007 Do you really need to measure this? I just torque them on as hard as I can by hand then re-check them after a short drive. Every shop I've ever been to has most definitely torqued them well past factory spec. I'm a little guy (read weak pussy) and I used to tighten lug nuts without a torgue wrench. Finally (after 30 + years) I damaged lugs and a stud on our Camry from over tightening. After getting the torgue wrench, I was amazed just how little 80 ft lb is. The wrench was cheaper than the damage I did. Shops with air wrenchs suck...they are lazy. I always retorque after I get home. It is still ugly. Link to comment Share on other sites More sharing options...
gianspi Posted May 2, 2007 Share Posted May 2, 2007 Actually, yes. Overtorqueing is just as bad as undertorqueing. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
rabydanimal Posted May 2, 2007 Share Posted May 2, 2007 Yeah, but how much can your overtorque by hand? I don't go balls to the wall, stomping on the damn tire iron. I just torque tightly and don't worry about it. That can't nearly be as bad as dumbass with air gun. Link to comment Share on other sites More sharing options...
feersum dreadnaught Posted May 2, 2007 Share Posted May 2, 2007 buy a 4' piece of 1.5" cast iron pipe. slide over torque wrench. leverage is your friend. you can now snap off any bolt you'd like. me, I just finger tighten them to 85 ft-lbs, cause my hands are as calibrated as my butt dyno... Link to comment Share on other sites More sharing options...
Hanger Posted May 2, 2007 Share Posted May 2, 2007 You have either become extremely weak or the wrench is broken. Since buying a torque wrench I have been amazed just how little 80 ft lb is. it's both possible that i've become extremely weak or the wrench is broken... ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
rao Posted May 2, 2007 Share Posted May 2, 2007 me, I just finger tighten them to 85 ft-lbs, cause my hands are as calibrated as my butt dyno... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
EL PAALO Posted May 2, 2007 Share Posted May 2, 2007 Yeah, but how much can your overtorque by hand? I don't go balls to the wall, stomping on the damn tire iron. I just torque tightly and don't worry about it. That can't nearly be as bad as dumbass with air gun. you can easily double it by hand. If the tire place you use doesn't properly torque them down ....... quit using that place. Link to comment Share on other sites More sharing options...
squishyface Posted May 3, 2007 Share Posted May 3, 2007 I was just swapping my rims today and according to the guys I was with and according to his chart, you can torque a LGT lugs to 89ft/lbs. 85 is the magic number. The hub is all one piece and if you over tighten you could easily screw up your bearing housing and then...well you know the rest. So I set my torque to 85 and left it there. Sean @ Rallitek also said no more than 85 for LGT's. There is actually a tool that will not let you torque down more than 85 ft/lbs it's used with air wrenches, I don't remember what it is called. I know it is not called a torque wrench. It is one piece, stationary and skinny in the middle...anyone know? Link to comment Share on other sites More sharing options...
pillboy Posted May 3, 2007 Share Posted May 3, 2007 I was just swapping my rims today and according to the guys I was with and according to his chart, you can torque a LGT lugs to 89ft/lbs. 85 is the magic number. The hub is all one piece and if you over tighten you could easily screw up your bearing housing and then...well you know the rest. So I set my torque to 85 and left it there. Sean @ Rallitek also said no more than 85 for LGT's. There is actually a tool that will not let you torque down more than 85 ft/lbs it's used with air wrenches, I don't remember what it is called. I know it is not called a torque wrench. It is one piece, stationary and skinny in the middle...anyone know? The sign on the wall at Discount Tire refers to it as a "torque stick". It is still ugly. Link to comment Share on other sites More sharing options...
squishyface Posted May 3, 2007 Share Posted May 3, 2007 Sweet cream of corn how easy is that to remember? Link to comment Share on other sites More sharing options...
trigeek Posted May 3, 2007 Author Share Posted May 3, 2007 Thanks to everyone for the help and advice (even BoxerGT2.5 who suggested I or my car might be special because it's a spec.B). Truth is I'm not mechanically inclined, but I am cheap. And this is the first car I've ever owned that I haven't just driven All Seasons on. Thanks again, you guys, and this site, are as always extremely helpful. Link to comment Share on other sites More sharing options...
TSiWRX Posted May 9, 2007 Share Posted May 9, 2007 me, I just finger tighten them to 85 ft-lbs, cause my hands are as calibrated as my butt dyno... Yet another success-story from Captains of Crush. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
rougeben83 Posted May 9, 2007 Share Posted May 9, 2007 Yeah, but how much can your overtorque by hand? I don't go balls to the wall, stomping on the damn tire iron. I just torque tightly and don't worry about it. That can't nearly be as bad as dumbass with air gun. You'd be surprised; you can torque it up to 100ft/lbs by hand pretty easy with the dinky factory wrench that subaru includes in the trunk. Just get a cheap torque wrench, I use a $20 one and torque mine up to 75. I'm more concerned about having the same torque on all 5 lugs on the same wheel because of problems I've had on past cars. Link to comment Share on other sites More sharing options...
