KRM Posted April 25, 2007 Share Posted April 25, 2007 anyone have the bolt tq for the front wheel hub? i need to replace mine cause almost every day it sounds like there is a tea kettle behind my drivers wheel. thanks for the help!!! Link to comment Share on other sites More sharing options...
rao Posted April 25, 2007 Share Posted April 25, 2007 Do you mean the axle nut? That is 162 ft lbs. The wheel hub assembly has 4 bolts and they are 48 ft lbs. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
edmundu Posted April 25, 2007 Share Posted April 25, 2007 47.9 ft/lbs for the 4 bolts that hold it to the knuckle. 162 ft/lbs for the axles nut. ^^What he said..... Link to comment Share on other sites More sharing options...
rao Posted April 25, 2007 Share Posted April 25, 2007 ^^^ I rounded because I'm not an engineer Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
edmundu Posted April 25, 2007 Share Posted April 25, 2007 I cut & pasted from the vaca pix:cool: Link to comment Share on other sites More sharing options...
KRM Posted April 25, 2007 Author Share Posted April 25, 2007 thanks every one!! Do any of you think a large 3 jaw puller will take this thing off? Link to comment Share on other sites More sharing options...
