ilh Posted April 1, 2007 Share Posted April 1, 2007 When taking off my stock winter wheels, the fronts where securely fastened to the hubs by corrosion. It took quite a lot of force on the wheel to jostle it loose. Is there anything recommended to use between the wheel and hub to minimize this in the future? I'm a little nervous about using something with too much lubricating properties in this location. I'm used to a good "punch" with the palm of my hand to knock a wheel loose, but this took 5-10 kicks with the bottom of my foot at pretty much maximum force. I was about to break out the sledge hammer. Link to comment Share on other sites More sharing options...
pillboy Posted April 2, 2007 Share Posted April 2, 2007 I use anti-sieze paste. Never had an issue. It is still ugly. Link to comment Share on other sites More sharing options...
rao Posted April 2, 2007 Share Posted April 2, 2007 I use anti-sieze paste. Never had an issue. +1 It is very typical. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
ilh Posted April 2, 2007 Author Share Posted April 2, 2007 Thanks. Link to comment Share on other sites More sharing options...
NEPA Posted April 2, 2007 Share Posted April 2, 2007 Changed my cousin's flat last year on a two year old Civic. Kicked the H out of it & it wouldn't break loose. Thought I was gonna have to call AAA to get it off - embarassing! Found a good smack against the tire with the spare does the job. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted April 2, 2007 Share Posted April 2, 2007 I lke to clean everything with an emery cloth and brake cleaner, then use some anti-sieze and wipe just a small amount of it around so it is only very thin layer. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
