laz Posted March 8, 2007 Share Posted March 8, 2007 I am a noob on this, but why use parts from both? http://i170.photobucket.com/albums/u280/garrett804/IMG_0338.jpg And not use the RX projector whole? Like why use hte shield from the Legacy, with the projector holder from the RX and lens from the legacy? X --- Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 8, 2007 Author Share Posted March 8, 2007 the rx lens is not clear it has tons of little divits like a golf ball has all over it. The legacy lens is clear but beveled. I'll post up a picture of the full Rx330 projector when I get home tonight and you'll understand why not once you see it. I used the Rx330 lens holder because with the legacy's it looked more yellow to me because the lens sits closer with the legacy holder then it does with the rx330. Check back later tonight or tomorrow and you'll see the pictures and understand why. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
laz Posted March 8, 2007 Share Posted March 8, 2007 the rx lens is not clear it has tons of little divits like a golf ball has all over it. The legacy lens is clear but beveled. I'll post up a picture of the full Rx330 projector when I get home tonight and you'll understand why not once you see it. I used the Rx330 lens holder because with the legacy's it looked more yellow to me because the lens sits closer with the legacy holder then it does with the rx330. Check back later tonight or tomorrow and you'll see the pictures and understand why. Ah like this: http://i170.photobucket.com/albums/u280/garrett804/IMG_0337.jpg But what about the shield? I though our shield has an opening on top. Did you fill that opening? And why not using the shhield off the RX? Also, what does the dimples do? And why is clear better? Sorry, just trying to understand all of this. X --- Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 8, 2007 Author Share Posted March 8, 2007 yes if you are going to do a retro you will be filling the shield hole to prevent against glare. As I said before you'll see why not to use the Rx330 shield. The main reason is it will not fit without a lot of cutting and grinding. the dimples just don't allow a clear transfer of light because the prizmatic geometry of each dimple takes away from the ability for light to pass through without some sort of coruption and change in the pattern of light. A fully clear lens like a TSX lens for example would allow a better passage for light to travel through with little to no distortion or disruption of the light. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
laz Posted March 8, 2007 Share Posted March 8, 2007 Ah thanks man! OK, then, now I think I got it. X --- Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 8, 2007 Author Share Posted March 8, 2007 ok, you'll see the pictures of the stock projector's tonight anyways so I'm sure you'll understand more why you have to switch it up. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 9, 2007 Author Share Posted March 9, 2007 Here's an image of the Stock Rx330 projector and as you can see the shield is huge and way unpruportioned to fit into hour housings. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
laz Posted March 9, 2007 Share Posted March 9, 2007 Got it! Thanks for the good info. I see now, said the blind man! X --- Link to comment Share on other sites More sharing options...
Guest Gitster Posted March 9, 2007 Share Posted March 9, 2007 Once you get your headlights you'll be doing this to them. http://i170.photobucket.com/albums/u280/garrett804/Cooking.jpg What do you use to power your oven? Plutonium?? It looks like your trying to strike a plasma in there. Link to comment Share on other sites More sharing options...
RobE Posted March 9, 2007 Share Posted March 9, 2007 What do you use to power your oven? Plutonium?? It looks like your trying to strike a plasma in there. :lol: its probably just his camera setting or a crappy camera http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
biz77 Posted March 10, 2007 Share Posted March 10, 2007 Just received my RX projectors. Just need to source my ballasts and bulbs. I hope to have mine done next month. Thanks for the write up. This should be a superior setup to the oem reflector setup on my STi. Link to comment Share on other sites More sharing options...
Guest Gitster Posted March 11, 2007 Share Posted March 11, 2007 How do HID driving lights do in moderate to heavy fog? I drove in some awful fog this morning and I was thinking that brighter / whiter HIDs would really reduce visibility in decent fog. Link to comment Share on other sites More sharing options...
TSiWRX Posted March 11, 2007 Share Posted March 11, 2007 ^ The pattern of light obtained from true "fog" optics/reflectors should help with visibility - however, the whiter/brighter aspect may make a negative impact. This will depend *highly* on your own personal preferences, and what seems to work best with your brain (versus someone else's). Going with selective yellow (in your case, HID, of course) fogs may prove to be a better move, if what you're worried about is foul-weather use, and if you're not willing to take the gamble above. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Guest Gitster Posted March 11, 2007 Share Posted March 11, 2007 Maybe a set of Fogs that actually increase visibility would help, I'm sure the "yellow" HID fog kits they have do wonders in fog. Running those independently of HID driving lights would be best in foul weather i'm assuming. Link to comment Share on other sites More sharing options...
slug6er Posted March 24, 2007 Share Posted March 24, 2007 just wondering what needs to be filled and where? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 25, 2007 Author Share Posted March 25, 2007 The little nipples have to be filled down flat. http://i170.photobucket.com/albums/u280/garrett804/Washersandgrinding.jpg OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
johndas Posted April 9, 2007 Share Posted April 9, 2007 Very interested as my HID's are not great...I like th e color but the output is very insatisfactory...I have the Xtech 5000k and want to improve this big time! I actually get a green tinge for some reason...might it be the lense? I will shut up now and follow along with this thread! J Link to comment Share on other sites More sharing options...
amg411 Posted April 10, 2007 Share Posted April 10, 2007 I'm wanting to do that but I don't know how to put them back together. Won't breaking that seal cause the housing to get moisture in it. Link to comment Share on other sites More sharing options...
TSiWRX Posted April 10, 2007 Share Posted April 10, 2007 ^ Not unless you accidentally got some water in there during your re-assembly. Honestly, though, yes, this remains a possibility, especially where there's actual physical "work" done to the housing - such as grinding away plastic using a Dremel tool, causing perhaps some dust to settle onto the OEM sealant, leading to a final result that's not fully weathersealed. However, if you use good care during your work, and then top-off with another small bead of sealant after you're done (to reinforce the factory sealant, that you've now broken), you should be just fine. This is what brother praedet speculated happened during our go at his headlamps. I've had my headlights apart 3 times (or so?) now. I still don't see any evidence of condensation or moisture ingress (knock-on-wood!). <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 11, 2007 Author Share Posted April 11, 2007 I've had my lights apart roughly 8 times now and have had no issue's ever. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Guest Gitster Posted April 11, 2007 Share Posted April 11, 2007 I've had my lights apart roughly 8 times now and have had no issue's ever. You must live in Southern California Link to comment Share on other sites More sharing options...
RobE Posted April 11, 2007 Share Posted April 11, 2007 twice here and ive never had a problem http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Guest Gitster Posted April 11, 2007 Share Posted April 11, 2007 I got condensation in both, and i only did it once. Must be the type of day it is. I heated both and resealed them with more silicon. Maybe I pried too much. Maybe next time ill put them in my car with full AC for hours to get rid of the humidity. Haha. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 11, 2007 Author Share Posted April 11, 2007 make sure you didn't put the vent caps back on ot tight aswell.. they are designed to allow the air to flow in and out to prevent condinsation OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
al-gorithm Posted April 14, 2007 Share Posted April 14, 2007 Does anyone have a better picture of the washer mod? I am having trouble visualizing the orientation/angle that the above picture is taken at. Link to comment Share on other sites More sharing options...
