waverunner Posted October 31, 2006 Share Posted October 31, 2006 getting ready to switch to synthetic transmission fluid cant find the type of fluid to use.dont hate on me,want to use either redline or amsoil and want to make sure i get the right kind. leaning towards the amsoil because i am able to buy it at cost and it has been around for over 35 years good stuff. thanks, i appreciate it! Link to comment Share on other sites More sharing options...
VTGT Posted October 31, 2006 Share Posted October 31, 2006 subscribe, is synthetic tranny oil worth using? Link to comment Share on other sites More sharing options...
TCSynthetics Posted November 1, 2006 Share Posted November 1, 2006 This is what AMSOIL recommends for your particular application: 2005 SUBARU LEGACY 2.5L 4-cyl VIN Code EJ255 Turbo FILTERS Oil Filter........EAO12 AMSOIL Ea Oil FilterOil Filter........51365 WIX 51365 Oil Filter (O)Oil Vapor Filter........N/RAir Filter........46914 WIX 46914 Air Filter (S) Fuel Filter........33558 WIX 33558 Gas Filter (O) Trans Filter........EAO12 AMSOIL Ea Oil FilterTrans Filter........51356 WIX 51356 Oil Filter (O) Cabin Filter........N/A BOSCH SPARK PLUGS All submodels: Plug........NA BOSCH WIPER BLADES All submodels: Driver side........B40924BOSCH MICRO EDGE WIPER BLADE Passenger side........B40918BOSCH MICRO EDGE WIPER BLADE LUBRICANTS & FLUIDS Engine Oil Grade 1......API* Series 2000 Synthetic 0W-30 Motor Oil SAE 5W-30 Synthetic Motor Oil SAE 5W-30 XL Synthetic Motor Oil Above -4°F......10W-30, 10W-40 All Temps......5W-30[1] Manual Transmission,.....GL-5 Below 30°C......80W Manual Transmission,.....GL-5 All TEMPS......75W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Manual Transmission,.....GL-5 Above 0°C......90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube SAE 80W-90 Synthetic Gear Lube Manual Transmission,.....GL-5 Above -30°C......85W Automatic Transmission.....SLF[2] Differential, Front .....GL-5[3] Above 0°C......90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube SAE 80W-90 Synthetic Gear Lube Differential, Rear .....GL-5[4] Above 0°C......90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube SAE 80W-90 Synthetic Gear Lube Fluids Power Steering Fluid.....AF3 Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Brake Fluid.....HB Clutch Fluid.....HB 1. SAE 5W-30 is preferred. 2. SLF is Subaru ATF, Part No. K0140Y0700 3. Front final drive is for automatic transmission only. 4. Rear DIFF is for 4WD models only. CHASSIS LUBRICATION 0 Fittings, 0 Plugs Cliff Twin City Synthetics, LLC twin-city-synthetics.com Link to comment Share on other sites More sharing options...
wukindada Posted November 1, 2006 Share Posted November 1, 2006 Go with BG for the ATF fluid, shifts are nice & smooth been running it for the past 15k. The warranty is a huge plus also:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Prime Power Posted March 22, 2007 Share Posted March 22, 2007 So am I reading that right, no Amsoil for our cars? Link to comment Share on other sites More sharing options...
jerseyglock Posted March 22, 2007 Share Posted March 22, 2007 So am I reading that right, no Amsoil for our cars? I'm on Amsoil since my 5EAT rebuild by IPT. IPT only use Amsoil. Link to comment Share on other sites More sharing options...
Prime Power Posted March 22, 2007 Share Posted March 22, 2007 I just checked it and they added it to the list of what we can use. Will do the whole flush myself with it @ 30k. Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted March 22, 2007 Share Posted March 22, 2007 ^^"They" meaning SOA? Just wanting to clarify.^^ YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
Prime Power Posted March 22, 2007 Share Posted March 22, 2007 Sorry, no they meaning Amsoil. Link to comment Share on other sites More sharing options...
VTGT Posted March 22, 2007 Share Posted March 22, 2007 has automatic synthetic fluid been proven to really help automatic transmissions? Link to comment Share on other sites More sharing options...
Prime Power Posted March 22, 2007 Share Posted March 22, 2007 well it will certainly lower temps. Some say though that it can cause slippage. Don't know for sure. Just added the bg stuff today. When the time comes though at 30k, I will use amsoil. Link to comment Share on other sites More sharing options...
Polo08816 Posted October 31, 2009 Share Posted October 31, 2009 Fluids Power Steering Fluid......AF3 Synthetic Universal Automatic Transmission Fluid (ATFQT) Power Steering Fluid......AF3 Torque-Drive Synthetic Transmission Fluid (ATD1G) Brake Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) Clutch Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) I wonder why Amsoil recommends 2 different ATFs for power steering fluid. Does anyone know the differences in either and if there will be a difference in feeling? It would seem pointless to order the Torque-Drive ATF at first glance because at least you can use the Synthetic Universal ATF for both the transmission and power steering. Link to comment Share on other sites More sharing options...
Prime Power Posted November 1, 2009 Share Posted November 1, 2009 I have been running the Amsoil in my tranny now for over a year. No probs. Link to comment Share on other sites More sharing options...
