Prod Posted October 3, 2006 Share Posted October 3, 2006 Take a look at these stats, and compare them to the LGT. Try and figure out what car it is. No cheating by copy/paste. http://www.jbskyline.net/PlatzhalterFFFFFF.gif Layout Front-engine / AWD Drag Coefficient [cd] NA Curb Weight [lb (kg)] 3395 (1540) [/url] Trunk Space [cu ft. (L)] NA Overall Length [in. (mm)] 181.1 (4600) Overall Width [in. (mm)] 70.3 (1785) Overall Height [in. (mm)] 53.5 (1360) Wheelbase [in. (mm)] 104.9 (2665) Track Front [in. (mm)] 58.3 (1480) Track Rear [in. (mm)] 58.7 (1490) Steering Rack & Pinion; Speed Sensitive Power Ass. Turning Radius [ft. (m)] 18 (5.6) Tires front 245/40 ZR18 Tires rear 245/40 ZR18 http://www.jbskyline.net/PlatzhalterFFFFFF.gif Engine http://www.jbskyline.net/PlatzhalterF0F0F0.gifhttp://www.jbskyline.net/PlatzhalterFFFFFF.gif Type Valvetrain dohc 4-valve/cyl Displacement [cc] 2568 Bore & Stroke [mm] 86.0 x 73.7 Compression Ratio 8.5:1 Redline [rpm] 8000 Max. Power [bhp at rpm] 327 at 6800 Max. Torque [lb-ft (Nm) at rpm] 293 (400) at 4400 Bhp/Liter 127.3 http://www.jbskyline.net/PlatzhalterFFFFFF.gif Gear Ratios http://www.jbskyline.net/PlatzhalterF0F0F0.gifhttp://www.jbskyline.net/PlatzhalterFFFFFF.gif 1st 3.827 2nd 2.360 3rd 1.685 4th 1.312 5th 1.000 6th 0.793 Final drive 3.545 http://www.jbskyline.net/PlatzhalterFFFFFF.gif Suspension http://www.jbskyline.net/PlatzhalterF0F0F0.gifhttp://www.jbskyline.net/PlatzhalterFFFFFF.gif Front MacPherson struts with an additional link, Lower A-Arms, Coil Springs Rear Mulitlink Setup with Coil Springs, Tube Shocks, Anti-Roll Bar http://www.jbskyline.net/PlatzhalterFFFFFF.gif Braking http://www.jbskyline.net/PlatzhalterF0F0F0.gifhttp://www.jbskyline.net/PlatzhalterFFFFFF.gif Front - Brakes 300mm ventilated discs with 4-piston calipers Rear - Brakes 280mm discs with 2-piston calipers 70 - 0 mph [ft (m)] 148 (46) 60 - 0 mph [ft (m)] 120 (36.6) http://www.jbskyline.net/PlatzhalterFFFFFF.gif Performance* http://www.jbroadtests.com/PlatzhalterF0F0F0.gifhttp://www.jbskyline.net/PlatzhalterFFFFFF.gif 0 - 60 mph [secs] 4.9 0 - 100 mph [secs] 12.3 1/4 mile [secs at mph] 13.7 at 103.5 Top Speed [mph] 155 Lateral acceleration [g] 0.88 Driver aside, I'm no longer really surprised that I beat it at the autocross. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted October 3, 2006 Share Posted October 3, 2006 I know what it is, and the driver must have blew....We Are! Link to comment Share on other sites More sharing options...
wukindada Posted October 3, 2006 Share Posted October 3, 2006 Does it start with a P & end with E? Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted October 3, 2006 Share Posted October 3, 2006 Skyline? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 3, 2006 Share Posted October 3, 2006 Skyline. Link to comment Share on other sites More sharing options...
rc0032 Posted October 3, 2006 Share Posted October 3, 2006 ....We Are! Penn State Link to comment Share on other sites More sharing options...
f1anatic Posted October 3, 2006 Share Posted October 3, 2006 Driver aside, I'm no longer really surprised that I beat it at the autocross. Can't be Skyline cause that is JDM yooo and they're like rarest to non-existant here. Link to comment Share on other sites More sharing options...
deimos Posted October 3, 2006 Share Posted October 3, 2006 I dunno about in the U.S, but we have a bunch up here in Canada, so Im sure there are a few kicking around down there. Link to comment Share on other sites More sharing options...
Prod Posted October 3, 2006 Author Share Posted October 3, 2006 R34 Skyline GT-R. The driver wasn't very good, but even so, the handling characteristics of the car seemed remarkably close to that of my LGT. Probably due to both cars having the same weight, same weight distribution, and AWD. Link to comment Share on other sites More sharing options...
