RaceComp Engineering Posted August 24, 2006 Author Share Posted August 24, 2006 The beauty of Ohlins struts is they have 25 levels of damping adjustment. Therefore, they are suited to a wide range of spring rates, from stock all the way beyond any standard spring that is available. So perhaps you would set them at 15 clicks from full soft for the RCE springs and 10 clicks for Pinks. Either way, they will bring the best out in any spring. The valving on the Ohlins is certainly beyond that of the Bilsteins (Ohlins is known for having some of the smoothest valving and most advanced technology around), but I can't say for sure how noticeable the difference would be. In our press release, we will have detailed technical info that should answer some of these questions more thoroughly. -Dan Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 24, 2006 Share Posted August 24, 2006 The beauty of Ohlins struts is they have 25 levels of damping adjustment. Therefore, they are suited to a wide range of spring rates, from stock all the way beyond any standard spring that is available. So perhaps you would set them at 15 clicks from full soft for the RCE springs and 10 clicks for Pinks. Either way, they will bring the best out in any spring. The valving on the Ohlins is certainly beyond that of the Bilsteins (Ohlins is known for having some of the smoothest valving and most advanced technology around), but I can't say for sure how noticeable the difference would be. In our press release, we will have detailed technical info that should answer some of these questions more thoroughly. -Dan Something with better valving then the Bilsteins? Keep us informed. I will need something to replace my Bilsteins with in a year or two. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Saul_Good Posted August 24, 2006 Share Posted August 24, 2006 Year or two?? I want them ASAP!! Link to comment Share on other sites More sharing options...
lhsa Posted August 24, 2006 Share Posted August 24, 2006 serious. can't wait for the ohlins. in the motorcycle world, they are the cream of the crop! Link to comment Share on other sites More sharing options...
aspringsteel Posted August 25, 2006 Share Posted August 25, 2006 Will your Ohlins struts and RCE springs combo be certified to work on the OBXT Wagon? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted August 25, 2006 Author Share Posted August 25, 2006 Technically they will work on the Outback BUT we can't exactly recommend it. Your ride height will be a LOT lower than stock, but if you are willing to deal with that it should work (in theory). You might want to try asking other Outback owners if they have run Legacy strut/spring combos with success before. -Dan Link to comment Share on other sites More sharing options...
HansGT Posted August 25, 2006 Share Posted August 25, 2006 RaceComp. I love my iON springs. Get a set and make a set like them and the take it a step further for one for the autocrossers. Link to comment Share on other sites More sharing options...
iON Performance Posted August 25, 2006 Share Posted August 25, 2006 Han'sGT - We actually have something that's slightly more aggresive then our Sport Specs designed to give more oversteer for auto-x and track. On the streets they are slightly "stiffer" then our Sport Specs RCE - The above statement is not ment to be a "treadjack" just clarifying some info Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted August 25, 2006 Author Share Posted August 25, 2006 No problem, but let's try to keep this thread on topic from now on...feedback for RACECOMP springs. -Dan Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted September 1, 2006 Author Share Posted September 1, 2006 bump Link to comment Share on other sites More sharing options...
Gawdly Posted September 1, 2006 Share Posted September 1, 2006 I'd like to see something built to compliment Bilsteins. Spec B owners would be knocking your doors down and we are growing in numbers in 07. Link to comment Share on other sites More sharing options...
suds2250 Posted September 5, 2006 Share Posted September 5, 2006 It seems all the springs on the market now drop at least 1 inch. I personally would like to see a spring available that is similar to the JDM stockers, that is 25% to 30% stiffer and a .5 to .75 inch drop. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted October 27, 2006 Author Share Posted October 27, 2006 As we get ready for the production of our Legacy springs...here is a teaser of the STi springs (ours are on the left, Ohlins coilover springs on right just for color clarification)...let us know if your interested, we will put you on a list, so that you can get first dibs on these. http://www.rcephotos.com/photos/albums/Racecomp-springs-packaging/legacyRCE.sized.jpg Link to comment Share on other sites More sharing options...
suds2250 Posted October 27, 2006 Share Posted October 27, 2006 What are the specs of the Legacy springs going to be? 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
Gmachine Posted October 28, 2006 Share Posted October 28, 2006 I currently run Swifts, and would like a bit more spring rate. How do these compare? Trying to max out the Bilsteins without resorting to coilovers. Dave Link to comment Share on other sites More sharing options...
zildjiank Posted October 28, 2006 Share Posted October 28, 2006 I've always thought: "The stiffer the better..." With average to aggressive ride drop... Maybe that's just me Link to comment Share on other sites More sharing options...
Tuned200 Posted October 28, 2006 Share Posted October 28, 2006 What are the specs of the Legacy springs going to be? x2 Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted October 30, 2006 Author Share Posted October 30, 2006 We don't have any official specs yet, but these, like the STi springs, will provide the best aspects of all springs combined into one. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 30, 2006 Share Posted October 30, 2006 We don't have any official specs yet, but these, like the STi springs, will provide the best aspects of all springs combined into one. I am sure they will be good, but they cannot be the best of everything, nothing is. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
groff Posted November 1, 2006 Share Posted November 1, 2006 +1 any new info? Link to comment Share on other sites More sharing options...
HansGT Posted February 12, 2007 Share Posted February 12, 2007 did this die? Link to comment Share on other sites More sharing options...
praedet Posted February 12, 2007 Share Posted February 12, 2007 ...What's happening Link to comment Share on other sites More sharing options...
