Vimy101 Posted August 8, 2006 Share Posted August 8, 2006 This is a lazy question but has anyone been able to convert Ipod (Itunes) to mp3 format and burned them to a CD. I took a quick look around on Itunes and they said it can be done but I tried and failed. The tunes burned but I got an error message. I could probably figure it out after farting around for a while but I was wondering if any of the members had experience with the proper proceedure. Thanks in advance. PS I did do some "searching" of the this (LGT) site. Link to comment Share on other sites More sharing options...
leftride Posted August 8, 2006 Share Posted August 8, 2006 burn them to a cd in mp3 format or to play in an cd player? mp3 format: iTunes 4: How to Create Your Own MP3 CDs audio cd: Burning an audio CD in iTunes for Windows (i assume you are a windows user) *vb gallery* Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 burn them to a cd in mp3 format or to play in an cd player? mp3 format: iTunes 4: How to Create Your Own MP3 CDs audio cd: Burning an audio CD in iTunes for Windows (i assume you are a windows user) Thanks for the reply. I read the page you linked and it appears as if the music has to be originally encoded as an mp3 in order to burn it to a disc. The second link appears to imply that the recorded format will be Itunes which the mp3 player does not support. Please correct me if I'm wrong. It looks like I'll have to re-import the music in the mp3 format and then burn away. Link to comment Share on other sites More sharing options...
SC GT Posted August 8, 2006 Share Posted August 8, 2006 Using iTunes, burn your AAC files onto a CD. Then, using mp3 playing program (like MusicMatch) burn the CDA files back onto your hard drive as mp3 files. Link to comment Share on other sites More sharing options...
VTsullyman Posted August 8, 2006 Share Posted August 8, 2006 Umm there is a very good coverter that is free (at least for 30 days) called DB power amp. It works great and can do alot. You can use the trail software or get it in the usual places. dBpowerAMP 2007 DGM LGT 2003 Suzuki SV650S Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 Using iTunes, burn your AAC files onto a CD. Then, using mp3 playing program (like MusicMatch) burn the CDA files back onto your hard drive as mp3 files. Cool. That sounds like it might just work. So I burn the Itunes onto a CD then convert them to mp3 using a Windows media player and then burn the new mp3s onto a CD-R? Link to comment Share on other sites More sharing options...
leftride Posted August 8, 2006 Share Posted August 8, 2006 what format are the files in your itunes library? you keep saying 'iTunes' do you mean iTMS acc protected files? *vb gallery* Link to comment Share on other sites More sharing options...
leftride Posted August 8, 2006 Share Posted August 8, 2006 Cool. That sounds like it might just work. So I burn the Itunes onto a CD then convert them to mp3 using a Windows media player and then burn the new mp3s onto a CD-R? you can rip them (import as mp3's) with iTunes as well *vb gallery* Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 what format are the files in your itunes library? you keep saying 'iTunes' do you mean iTMS acc protected files? That must be the format in which the original tunes downloaded into. When I burn a CD in mp3 format I get an error message saying they can't be played. Link to comment Share on other sites More sharing options...
SC GT Posted August 8, 2006 Share Posted August 8, 2006 Cool. That sounds like it might just work. So I burn the Itunes onto a CD then convert them to mp3 using a Windows media player and then burn the new mp3s onto a CD-R? Yeah. As I understood your first post, you want to convert copy-protected AAC files bought through iTunes to mp3 files, correct? That will do the trick as long as your Windows media player converts them to mp3, and not wma. Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 you can rip them (import as mp3's) with iTunes as well I will do that in future. However, I just don't want to go digging through all my CD and re-export them into Itunes again. Since the music is already there - albeit in a non mp3 format - I was hoping to just use that data. Thanks to the tips from you guys, I might just be able to do that. Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 Yeah. As I understood your first post, you want to convert copy-protected AAC files bought through iTunes to mp3 files, correct? That will do the trick as long as your Windows media player converts them to mp3, and not wma. Right. Err... wrong. These tunes are all from my own CD collection that I downloaded into Itunes in order to transfer them to my Ipod. Link to comment Share on other sites More sharing options...
leftride Posted August 8, 2006 Share Posted August 8, 2006 ah ok try this... Go into iTunes Preferences, and change the importing mode back to the MP3 mode you like Now select the tracks that you want to change to mp3, and go to the Advanced menu. There is an item called "convert selection to MP3". This will convert them to mp3 (you will loose some quality, but you probably wont be able to tell) and then you can burn them as an mp3 using my previous post. *vb gallery* Link to comment Share on other sites More sharing options...
Vimy101 Posted August 8, 2006 Author Share Posted August 8, 2006 I will try it as soon as I get back to the 'puter I've got the Itunes on. Link to comment Share on other sites More sharing options...
SC GT Posted August 8, 2006 Share Posted August 8, 2006 Right. Err... wrong. These tunes are all from my own CD collection that I downloaded into Itunes in order to transfer them to my Ipod. Oh. Other than the few that I've purchased on iTunes, all of my songs are in mp3 format on my ipod. My method will still work for you though. Link to comment Share on other sites More sharing options...
Boulderguy Posted August 8, 2006 Share Posted August 8, 2006 OK Itunes studs - try this one: I'm looking for a way to sidestep actually making a physical CD using the above process of going from Itunes purchases to MP3. So I DL'ed music from Itunes store in protected format. Is there a way, rather a program, that will create a virtual CD drive that Itunes will recognize as a physical drive & "burn" the music CD to the HD instead of having to use an actual CD? Basically want to stop throwing out CDs after having re-ripped them into MP3 - ideas? BTW, I've been using CDex for years, great encoder, & fast too. Link to comment Share on other sites More sharing options...
SC GT Posted August 8, 2006 Share Posted August 8, 2006 OK Itunes studs - try this one: I'm looking for a way to sidestep actually making a physical CD using the above process of going from Itunes purchases to MP3. So I DL'ed music from Itunes store in protected format. Is there a way, rather a program, that will create a virtual CD drive that Itunes will recognize as a physical drive & "burn" the music CD to the HD instead of having to use an actual CD? Basically want to stop throwing out CDs after having re-ripped them into MP3 - ideas? BTW, I've been using CDex for years, great encoder, & fast too. CD-RW? Link to comment Share on other sites More sharing options...
leftride Posted August 8, 2006 Share Posted August 8, 2006 ^ peep this: hymn :: View topic - JHymn and iTunes 6 FAQ -- by XOR & hymn :: View topic - JHymn 0.9.2 now available (doesn't fix iTunes 6 problems) *vb gallery* Link to comment Share on other sites More sharing options...
Boulderguy Posted August 9, 2006 Share Posted August 9, 2006 Hey, you're good! Have you used Hymn? Link to comment Share on other sites More sharing options...
johnAWD Posted August 9, 2006 Share Posted August 9, 2006 I've heard that jhymn will remove the DRM signature from certain types of files, and that it will also convert to mp3. Just what I've heard. Link to comment Share on other sites More sharing options...
leftride Posted August 9, 2006 Share Posted August 9, 2006 Hey, you're good! Have you used Hymn? no i haven't. i dont buy DMR "protected" music....i understand the reason to do it, its just a pain to deal with. I have used some dmr removers, but its been a few versions and iTunes is doing a good job on preventing the DRM removal...i dont really think there is much to do after iTunes v6 though. *vb gallery* Link to comment Share on other sites More sharing options...
leftride Posted August 9, 2006 Share Posted August 9, 2006 another note, just as an fyi for everyone * burning to cd and re-ripiing to mp3/aac will reduce quality * converting from mp3 to aac vice-versa will reduce quality you might not be able to hear it but they are both a lossy format so you are loosing info when compressing. *vb gallery* Link to comment Share on other sites More sharing options...
ilh Posted August 9, 2006 Share Posted August 9, 2006 If you have an iPod, why not get a Jazzy board and attach the iPod directly to your car? Who wants to screw around with the lousy user interface of your car stereo playing a CD full of MP3s? iPod + Jazzy FTW! Link to comment Share on other sites More sharing options...
leftride Posted August 9, 2006 Share Posted August 9, 2006 The guys at apple who came up with this need to be whacked with a ball-peen hammer... um....apple isnt the only company that implements drm. i actually think they have done an ok job of implementing it, so they are the best of the worst. *vb gallery* Link to comment Share on other sites More sharing options...
Vimy101 Posted August 9, 2006 Author Share Posted August 9, 2006 If you have an iPod, why not get a Jazzy board and attach the iPod directly to your car? Who wants to screw around with the lousy user interface of your car stereo playing a CD full of MP3s? iPod + Jazzy FTW! You're not playing the music, you just bought a certain system that reproduces it. Gramophone wax cylinders or DVD. You don't own the sounds. Merely the medium in which the recorded sound is reproduced. It might drive you nuts but it is fair and their right not yours. Unless you strike a deal with the artist saying that you have a right to their created sound product on any format and the distribution company has to keep you supplied with the latest reproduction formats because you paid the artist for that right. The digital age is weird. Used to be that in order to hear music you either made it yourself or you paid someone else to make it for you. Link to comment Share on other sites More sharing options...
