SC GT Posted August 8, 2006 Share Posted August 8, 2006 eBay Motors: 02 OXYGEN SENSOR SOCKET FOR THE CRAFTSMAN 3/8 dr 22mm (item 320014213407 end time Aug-14-06 19:45:00 PDT) Would like to buy one so that I can switch out my own DP. Would this one work, or do I need to buy the one with the offset? Thanks. Link to comment Share on other sites More sharing options...
REM87O Posted August 8, 2006 Share Posted August 8, 2006 Maybe a little deep, I would go with the shorter crows foot version. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 8, 2006 Share Posted August 8, 2006 Looks a little deep for me, too.... Might work fine for the manifold O2, but for the 3rd-cat O2, you might need to drop the pipe/cat section in order to use this particular socket/wrench..... Your local auto-parts store should carry the same item, only quite a bit shorter (and "crow's foot," for lack of better terminology), for about the same price as you'd have from that auction + shipping. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
PGT Posted August 8, 2006 Share Posted August 8, 2006 yup...you need the offset kind. better: http://static.summitracing.com/global/images/prod/large/sum-w84008_w.jpg most common (works, but tight fit): http://www.midwayautosupply.com/images/wilmar/w84008_3X.jpg Link to comment Share on other sites More sharing options...
PGT Posted August 8, 2006 Share Posted August 8, 2006 just be careful when reinstalling the O2. It doesn't need much torque to seal. We literally shattered two offset O2 sockets trying to remove it. Link to comment Share on other sites More sharing options...
SC GT Posted August 8, 2006 Author Share Posted August 8, 2006 Thanks for the quick feedback. Looks like I'll be purchasing the offset socket. Link to comment Share on other sites More sharing options...
REM87O Posted August 8, 2006 Share Posted August 8, 2006 I know my local AutoZone sells the whole set (3) in the range of $10-$12. Well worth it in my book. Link to comment Share on other sites More sharing options...
rc0032 Posted August 8, 2006 Share Posted August 8, 2006 I have the one like your eBay one and it works fine Link to comment Share on other sites More sharing options...
rony Posted August 8, 2006 Share Posted August 8, 2006 I have the one like your eBay one and it works fine I had problems with the deep socket one. I just went to autozone and bought the offset (crow foot) one for $10. My Car vBGarage Link to comment Share on other sites More sharing options...
Waxiboy Posted August 8, 2006 Share Posted August 8, 2006 Do you really need an O2 socket? Won't a regular wrench do the trick? Link to comment Share on other sites More sharing options...
REM87O Posted August 8, 2006 Share Posted August 8, 2006 I have used a regular wrench before you just run the risk of rounding. Link to comment Share on other sites More sharing options...
PGT Posted August 8, 2006 Share Posted August 8, 2006 7/8 or 22mm, yes. If you can get enough contact to keep from stripping it. Another way is to unplug it at the Molex and remove the O2 from the pipe once off the car. This is a good way to protect your knuckles if the O2 doesn't want to budge Link to comment Share on other sites More sharing options...
rc0032 Posted August 8, 2006 Share Posted August 8, 2006 Do you really need an O2 socket? Won't a regular wrench do the trick? No dont do it Link to comment Share on other sites More sharing options...
jsalicru Posted August 8, 2006 Share Posted August 8, 2006 just be careful when reinstalling the O2. It doesn't need much torque to seal. We literally shattered two offset O2 sockets trying to remove it. per my thread at the top of this page (that you stickied yourself) Front 02 sensor torque spec ...................22.1 ft-lbs "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
