KGreb Posted August 2, 2006 Share Posted August 2, 2006 FYI for those who do not follow the EM forum on NASIOC. The long awaited new UTEC firmware update for the STI (and LGT and FXT) is out. You can download it here: Turbo XS - Software updates. The firmware adds speed density (MAP only operation) for the high power cars. Also adds injector dead time control, improved boost control using a PID algorithm, rev limit control, more control over open loop/closed loop transitions, and lots of other nice improvements. This firmware seems to have completely removed the open loop/closed loop hesitation on my car. I did no retuning, just uploaded the new firmware and parameter file, tweaked the param file for my injectors, then uploaded my old maps. Going to try setting up the new PID boost control next. I highly recommend the upgrade for anyone running a UTEC. Link to comment Share on other sites More sharing options...
chohakai Posted August 2, 2006 Share Posted August 2, 2006 wooohooo!!!! it's about FU**ING TIME!!!! Link to comment Share on other sites More sharing options...
MDTURBO Posted August 2, 2006 Share Posted August 2, 2006 ^^ +1 * 11ty-billion 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
SQC049 Posted August 2, 2006 Share Posted August 2, 2006 Cool, I'll let my brother now. Will he have to re-tune after the update? Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
KGreb Posted August 2, 2006 Author Share Posted August 2, 2006 I didn't need to retune fuel, boost, or ignition and it works great. Much smoother than before. The only changes I made were to the new parameter file as it was set for stock injectors and I am using modified stockers. Link to comment Share on other sites More sharing options...
rao Posted August 2, 2006 Share Posted August 2, 2006 Interesting... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
MDTURBO Posted August 2, 2006 Share Posted August 2, 2006 who's going speed density now??? 2012 Forester XT. Stage 2+ Retired from Racing. I used to build FMIC and more. Link to comment Share on other sites More sharing options...
KGreb Posted August 2, 2006 Author Share Posted August 2, 2006 No speed density plans here, but it nice to know its there if I want it I think all the <$700 used STI UTECs that were flooding the NASIOC classifieds are all gone within the last 24 hrs Link to comment Share on other sites More sharing options...
Jon in CT Posted August 2, 2006 Share Posted August 2, 2006 Unless you're planning on at least 39 lbs/min air intake, there's no sense in using UTEC's speed-density, expecially given that it tries to estimate density from compressor inlet temperature instead of cylinder inlet temperature. Link to comment Share on other sites More sharing options...
KGreb Posted August 2, 2006 Author Share Posted August 2, 2006 Agreed, you want a different IAT sensor location for true speed density. Using the MAF IAT is definitely a compromise. However, I did so on a different standalone system (Link for Miata) for several years until upgrading to a properly placed sensor and it still ran quite well. Link to comment Share on other sites More sharing options...
Xenonk Posted August 3, 2006 Share Posted August 3, 2006 KGreb, what are you running along with your UTEC? and how long have you been using the UTEC on your GT? Keefe Link to comment Share on other sites More sharing options...
KGreb Posted August 3, 2006 Author Share Posted August 3, 2006 20G, TMIC, and the usual fuel/exhaust support pieces. Kept the stock cans so it is somewhat stealthly. Running ECUTek from PDX for over a year. Added the UTEC on top about 4 months ago. Have an unresolved issue holding boost with the 20G, so its not reaching full potential, but still a lot of fun. Link to comment Share on other sites More sharing options...
chohakai Posted August 3, 2006 Share Posted August 3, 2006 Haha, stock cans is probably what's holding the boost back... Go for a run with the catback uninstalled.... It'll probably solve your boost issues... 20G, TMIC, and the usual fuel/exhaust support pieces. Kept the stock cans so it is somewhat stealthly. Running ECUTek from PDX for over a year. Added the UTEC on top about 4 months ago. Have an unresolved issue holding boost with the 20G, so its not reaching full potential, but still a lot of fun. Link to comment Share on other sites More sharing options...
team23jordan Posted August 3, 2006 Share Posted August 3, 2006 thanks for the heads up! i'm gonna do this tommorow!! Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
team23jordan Posted August 3, 2006 Share Posted August 3, 2006 btw, how do i save my old tune? and reload'em? EDIT do i load all 3 files?? (STI_A_SERIES_2.3.mot, STI_2.3.mot, STIDBW_4.mot) Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
KGreb Posted August 3, 2006 Author Share Posted August 3, 2006 btw, how do i save my old tune? and reload'em? EDIT do i load all 3 files?? (STI_A_SERIES_2.3.mot, STI_2.3.mot, STIDBW_4.mot) Go to the edit map screen and transfer your maps to the PC. Just follow the directions on screen, very simple. There are two versions of the processor out there so you may need to try both 2.3 and 2.3 A. Try the 2.3 first, then try to upload a map. If it doesn't save properly, (no details with the map slot) you need to load 2.3A instead. This is all in the instructions provided with the files. Do not install the DBW firmware. Link to comment Share on other sites More sharing options...
KGreb Posted August 3, 2006 Author Share Posted August 3, 2006 Haha, stock cans is probably what's holding the boost back... Go for a run with the catback uninstalled.... It'll probably solve your boost issues... Sorry, try again. I did a run with them removed and it made zero difference. Going from stock center to Perrin center also made zero difference to boost levels. Also adding a GFB BOV made zero difference to boost levels. Working with Deadbolt to rule out issues with the WG actuator or flapper, but I travel a lot for work so this is going slowly. Link to comment Share on other sites More sharing options...
johnAWD Posted August 3, 2006 Share Posted August 3, 2006 Kgreb - have you tried using boost control outside of what the utec does? MBC or similar? What is the actuator spring rated at? Link to comment Share on other sites More sharing options...
KGreb Posted August 3, 2006 Author Share Posted August 3, 2006 Kgreb - have you tried using boost control outside of what the utec does? MBC or similar? What is the actuator spring rated at? WG should have a 15 psi spring. Direct mechanical control gives ~10-11 psi. I can pull the WG sense line and I get the same boost curve as with the UTEC, so this isn't a UTEC or stock boost solenoid limitation. I can hit ~18.5 psi midrange but I fall to ~15.5 psi by redline. The turbo should be capable of more. I seem to get all the fun problems Link to comment Share on other sites More sharing options...
team23jordan Posted August 4, 2006 Share Posted August 4, 2006 Do not install the DBW firmware. whats DBW firmware and why do you recomment not installint the dbw? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
KGreb Posted August 4, 2006 Author Share Posted August 4, 2006 whats DBW firmware and why do you recomment not installint the dbw? On some of the STI UTECs there is a second processor which can control the drive by wire (DBW, actually only throttle by wire) function of the ECU. TXS included a DBW firmware file in the zip archive, but left no instructions for it. Nathan @TXS recommended not to touch this file when I asked about it. Link to comment Share on other sites More sharing options...
GTTuner Posted August 4, 2006 Share Posted August 4, 2006 Question; Why would you want to go to a speed density system over MAF system. Speed density is a slower input than a MAF and relies on the TPS for quick changes in throttle/load signal, sort of an electronic acclerator pump, if you will. I ask this because all the "Mustang" heads switch the older fox body cars over to MAF when they do mod's. (the early EFI 5.0's were speed density) I personally prefer a speed density system of a MAF due to ease of diagnostics and plain ol' reliability issues with MAF sensors. Just curious.....and interested even though I'm running an AP. Link to comment Share on other sites More sharing options...
KGreb Posted August 4, 2006 Author Share Posted August 4, 2006 Speed density was included primarily for the folks who were running at the maximum limit of the MAF sensor. It seems to be more popular to go to a MAP system than to do the work to integrate a larger MAF properly. Link to comment Share on other sites More sharing options...
team23jordan Posted August 6, 2006 Share Posted August 6, 2006 for some reason, i can't load'em I get this ERROR: Found no units on any port Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
chohakai Posted August 7, 2006 Share Posted August 7, 2006 for some reason, i can't load'em I get this ERROR: Found no units on any port Make sure that you have your toggle switch or dip switches set to 'Flash'. And no Hyperterminal or anything else running at the same time. I had some issues with upgrading the firmware as well, it appears that the USB-to-Serial adapter is not very stable. And once the upgrade failed I couldn't start the car anymore, and couldn't get the flash loader to talk to the UTEC again. So I had to take the UTEC off of the car to do it, and I had to play around with different port speed (from within the Flash Loader)... It finally worked hours later.... Link to comment Share on other sites More sharing options...
