c-lo Posted July 17, 2006 Share Posted July 17, 2006 took apart the air box this morning and cleaned my air filter. 1/2 way into the project, got side tracked. had to drive the wife to a clinic she was helping out at......seems she had a bit of a hangover:lol: . PROBLEM: put everything back together about 3 hours later. turned the car on and check engine light is flashing. seems to me this has been covered before....... should I ignore till it goes off? or bring it to the stealership? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
G.T.Subie Posted July 17, 2006 Share Posted July 17, 2006 Me and my wife are pretty hung over too:icon_cool. Did you plug the sensor in? Denial is your best friend Link to comment Share on other sites More sharing options...
fatbastard Posted July 17, 2006 Share Posted July 17, 2006 I would check the MAF sensor plug and for some reason Subaru recommends reseting teh ECU with air filter change Link to comment Share on other sites More sharing options...
Opie Posted July 17, 2006 Share Posted July 17, 2006 Or if the air box is not reassembled correctly and is sucking in additional air it can throw the light on as well... Link to comment Share on other sites More sharing options...
c-lo Posted July 17, 2006 Author Share Posted July 17, 2006 plug is plugged in. I"ll double check airbox, but it should be ok. didn't get a chance to leave my parking spot before the light came on. as soon as I turned on the ignition it came on. reset the ecu. didn't have to do that when I put the perrin airfilter in originally, but how to do? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted July 17, 2006 Share Posted July 17, 2006 Disconnect the Neg on the Battery for at least 30 secs If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
c-lo Posted July 17, 2006 Author Share Posted July 17, 2006 Disconnect the Neg on the Battery for at least 30 secs I'm good......problem fixed itself this morning! 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
wukindada Posted July 17, 2006 Share Posted July 17, 2006 c-lo.......you cleaned your filter already? How many miles did you put on it? Glad the ECU reset took care of it for you:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
