taskforcefreddy Posted July 15, 2006 Share Posted July 15, 2006 I recently purchased a Cobb UP/DP and E tune from TDC and am contemplating doing it myself and have found a plethora (that's a great word) of info here on LGT.com. Something I've come across is that when installing the UP is that you'll need to pull the exhaust manifold off the vehicle which, after seeing some pics, doesn't look too bad at all. My question is that as long as I'm pulling it off, should I look into replacing it with a header set and if so, which one? I've seen Borla and that's about it. Does anyone know if we can use an aftermarket header for an STI on our vehicles? I saw one guy with a 5EAT that had a header... anyone else with some dyno/performance info on doing this... possibly with a manual transmission? Thanks much on advanced. Link to comment Share on other sites More sharing options...
JBLU24 Posted July 15, 2006 Share Posted July 15, 2006 u dont need to pull off the exhaust manifold to install an UP/DP dont know where you read that.... if you want a header may as well sell your cobb UP and ask TDC to send you one of the GT Spec headers w/UP that they recommend.... Link to comment Share on other sites More sharing options...
1freak Posted July 15, 2006 Share Posted July 15, 2006 u dont need to pull off the exhaust manifold to install an UP/DP dont know where you read that.... if you want a header may as well sell your cobb UP and ask TDC to send you one of the GT Spec headers w/UP that they recommend.... +1 on both check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
taskforcefreddy Posted July 15, 2006 Author Share Posted July 15, 2006 Roger... I read that you don't have to, it's just easier in the long run. I'll hit up TDC and see what they say. Anyway out there using the GT Spec set-up? Link to comment Share on other sites More sharing options...
TDC Joe Posted July 15, 2006 Share Posted July 15, 2006 They are correct, you don't HAVE to. It would just make the install easier. We recomment GT Spec headers that come with an integrated UP with a veocity stack in it. So you wouldn't need the UP you just bought. I say install what you have. The headers are an easy install later anyway if you wanted to. Otherwise you will take a small loss on the pipe you just bought. Joe PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
1freak Posted July 15, 2006 Share Posted July 15, 2006 Roger... I read that you don't have to, it's just easier in the long run. I'll hit up TDC and see what they say. Anyway out there using the GT Spec set-up? John at TDC is running them and has dyno plots somewhere I'm sure. I have them but cannot comment on them yet, I havent installed them yet check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
TDC Joe Posted July 15, 2006 Share Posted July 15, 2006 We have a bunch of people running them and a lot more orders coming in for them all the time. There will be a 2005 5EAT coming up here in the next few weeks to put them on with a bunch of other stage II stuff already on. I am sure that dyno will get posted. PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
franklin Posted July 15, 2006 Share Posted July 15, 2006 TDC Tuning II. At stage II with your tune how much more is there with headers over a uppie and turboback? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 15, 2006 Share Posted July 15, 2006 Also get the headers coated. I had mine on for 6 months (all in the winter, so it never even saw a hot day) and it slowly melted my plastic undertray, making it hard to get the oil-filter access panel off. One of the clips is melted to nothing. I also had 3 leaking oil filters. Get them coated and not have the above problems, plus you willl get less heat soak and better spool! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
franklin Posted July 15, 2006 Share Posted July 15, 2006 Also get the headers coated. I had mine on for 6 months (all in the winter, so it never even saw a hot day) and it slowly melted my plastic undertray, making it hard to get the oil-filter access panel off. One of the clips is melted to nothing. I also had 3 leaking oil filters. Get them coated and not have the above problems, plus you willl get less heat soak and better spool! Thanks for the advise. Could help some avoid these issues. Link to comment Share on other sites More sharing options...
Opie Posted July 16, 2006 Share Posted July 16, 2006 Don't forget about the APS equal length header with up-pipe...it is wicked. http://www.aps-wrx.com/us_spec/subaru/sti/headers/installed2.jpg Link to comment Share on other sites More sharing options...
johnAWD Posted July 16, 2006 Share Posted July 16, 2006 Opie - who did you buy the header/UP through? What did the set cost? Link to comment Share on other sites More sharing options...
Steiner Posted July 16, 2006 Share Posted July 16, 2006 Don't forget about the APS equal length header with up-pipe...it is wicked. http://www.aps-wrx.com/us_spec/subaru/sti/headers/installed2.jpg ^^^^ Skeeeet!!! Experience is something you don't get until right after you needed it. Link to comment Share on other sites More sharing options...
wukindada Posted July 16, 2006 Share Posted July 16, 2006 Opie has been spending again.......... Very nice! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Mblock66 Posted July 16, 2006 Share Posted July 16, 2006 They look purdy! Are you going to coat or wrap them? Link to comment Share on other sites More sharing options...
wukindada Posted July 16, 2006 Share Posted July 16, 2006 Nah........ Opie is all about the BLING......BLING:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Opie Posted July 16, 2006 Share Posted July 16, 2006 Haha, that pic isn't of my car! My header is still stock. A local shop has a bunch of those APS headers in stock and keep bugging me to buy one. I think they are $995.00...to much for me at the moment...adding on to the house instead... Link to comment Share on other sites More sharing options...
wukindada Posted July 16, 2006 Share Posted July 16, 2006 So there on another regal blue LGT....... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
eL GaTo Posted July 16, 2006 Share Posted July 16, 2006 Header Installed.jpg Swain Tech Coated GT Spec.jpg GT Spec with Uppipe and Swain Tech coated. "Remember..."MODDING is a HOBBY:icon_bigg, not a BAAAD HABIT";) . Link to comment Share on other sites More sharing options...
zildjiank Posted July 16, 2006 Share Posted July 16, 2006 Do the headers, UP/DP all at the same time...exactly what I'm doin... You'll be in for it once you step up that far from stage 1...at least that's what i'm hoping... Just make sure you aquire all the parts you need...that was/is a pain and headache for me... Link to comment Share on other sites More sharing options...
SpeedNeeder Posted July 17, 2006 Share Posted July 17, 2006 I remember another post said gt spec headers gained 11hp/18tq on an STI. Not sure what headers would do on a stage 2 LGT. Maybe TDC will let us know soon. I'm disappointed to hear about the melting??? I was really hoping the $200 coating wasn't necessary. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 17, 2006 Share Posted July 17, 2006 I remember another post said gt spec headers gained 11hp/18tq on an STI. Not sure what headers would do on a stage 2 LGT. Maybe TDC will let us know soon. I'm disappointed to hear about the melting??? I was really hoping the $200 coating wasn't necessary. Just get it coated, better spool and less heat-soak is always a good thing! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
