Shangsta Posted July 12, 2006 Share Posted July 12, 2006 left nut for? Personally i would give both to drive one of these but i probably need em to drive it:lol: . My choice a Daur Porsche 962 the ultimate sportscar:wub: http://www.supercars.net/PicFetch?pic=1994_dauer_962_lm-3.jpg price $1 200 000 USD engine Porsche Watercooled Flat-6 position Mid Longitudinal aspiration Twin KKK turbochargers valvetrain Quad Cam, 4 Valves / Cyl fuel feed TAG Mototronic Fuel Injection displacement 2994 cc / 182.7 cu in bore 95.0 mm / 3.74 in stroke 70.4 mm / 2.77 in compression 9.0:1 power 544.4 kw / 730.0 bhp @ 7400 rpm hp per litre 243.82 bhp per litre bhp/weight 708.74 bhp per weight torque 700.9 nm / 517.0 ft lbs @ 5000 rpm redline 7800 drive wheels RWD w/Limited Slip Differential body / frame Carbon Fibre / Kevlar front brakes Brembro Ventilated Discs w/4-Piston Calipers f brake size 330 mm / 13.0 in rear brakes Brembro Ventilated Discs w/4-Piston Calipers r brake size 330 mm / 13.0 in front wheels F 45.7 x 26.7 cm / 18 x 10.5 in rear wheels R 45.7 x 33.0 cm / 18.0 x 13 in front tire size 285/30ZR-18 rear tire size 345/35ZR-18 f suspension Double Wishbones w/Adj Anti-Roll Bars, Spring/Damper Units r suspension Double Inverted Wishbones w/Radius Rods, Adj Anti-Roll Bars, Spring/Damper Units weight 1030 kg / 2271 lbs length 4650 mm / 183.1 in width 1985 mm / 78.1 in height 1050 mm / 41.3 in transmission Porsche 5-Speed Manual w/Tiptronic Control, Hydraulic Sinter Clutch top speed 404.6 kph / 251.4 mph 0 - 60 mph 2.6 seconds drag 0.31Cd In the late nineties, bringing prototype racecars to urban roadways was an idea that several companies shared. Considering the contrast between sports car and race car engineering, embarking on such a project was a laborious task. Coupled with the limited production and tiny customer base, development costs were hard to recoup. Despite these hardships, several German companies still decided to create their own road-going Porsche 962, the most successful prototype race car of our time. From 1983 forward, the Porsche 956 and its 962 IMSA spec version dominated for a decade. Porsche manufactured nearly 150 956/962s and sold many of the cars to private teams. During this period, Porsche manufactured and made available every component on the car. Due to this customer support, Porsche not only became the most successful marque at Le Mans, but also provided essential parts for companies, such as DP Motorsport, Schuppan, Koenig and Dauer, to make road-going specials. Of the companies that have produced a 962 road car, the most successful has been Dauer. After displaying their first 962 at the 1993 Frankfurt Show, Dauer partnered with Porsche to manufacture a contender for the 1994 24 Hours of LeMans. At that time the prototype rules stipulated that a single road-going version of the car had to manufactured for homologation. As a result of these regulations, several homologation specials were born from the world's fastest racecars. These included the Porsche GT1, Mercedes-Benz CLK GTR and our feature car, the Dauer 962 LM. What good times. At the 24 hour race, Dauer showed up with both a road version and race version of the Porsches 962, a design which had already won Le Mans six times. After winning the race, the FIA declared it would be creating rules to make sure the 962 wouldn't be back in 1995. However, with a Le Mans win under their belt, and with support from Porsche, Dauer continued to build their road-going 962. 962LM in Detail Since the 1994 victory, much has changed at Dauer as attention focused from street legal racecar to civilized roadcar. To create each one of these cars, Dauer takes an original Porsche-made 956/962 and strips the car. A completely new carbon fiber/kevlar body is then made along with a very tight leather interior . When finished, the owner receives a car which has a race history at the top level of motorsport and is also ready to drive on local streets. A major development has been the introduction of several electro-hydraulic systems into the car. While equipped with pneumatic doors and rear engine cover, one of the most important changes is a hydraulic suspension to raise and lower the car. This was manditory as the 962, in standard trim, is far too low to meet the ride height necessitated by German law. Inside, Dauer have made the cockpit a more civil affair. Reinald Mattes spent considerable time to fitting two seats into a very tight cockpit. After the moulds were completed, Dauer formed carbon fibre panels and covered them in leather. Interesting features include interior-cooling, a detachable steering wheel and properly detailed luggage. Still, the 962 is a very unforgiving machine, and it is doubtful that any driver will have time to watch, yet alone hear the DVD player provided. Powering the 962 is the same 2994cc water-cooled Porsche flat-six found in the race car. A pair of intercooled KKK turbochargers are employed and the engine has 'softer' cams for more tractable driving. Thanks to racing catalytic convertors and Bosch Motronic 1.7 engine management, the 962 meets European emissions regulations. Attached to the engine is a unique transmission that uses the normal 962 manual box and clutch. But instead of using a gear lever, the driver select ratios via the Tiptronic S style knobs on the steering wheel. At 1080kg, the 962LM may weigh around 180kg more than the 962 racecar, but its power-to weight ratio is still better than the McLaren F1's. In a drag start, 0-60mph takes around 2.6 seconds in first gear! Five seconds later you have doubled your speed again. Ultimately a shade over 250mph is possible. A top speed test was conducted on the Ehra-Leissen VW test track, where 404.6 kph was achieved. In total 13 Dauer conversions have been finished, and Dauer are still taking orders for more cars. They are also finishing up a very limited run of Bugatti EB110s that were sold in pieces to Dauer when the company closed. We have also heard that Dauer is updating their 962 and a 2006 model is in the works. Story by Richard Owen for Supercars.net Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted July 12, 2006 Share Posted July 12, 2006 Let's see.... McLaren F1, natch. The king, especially the LM road car version. (see avatar) Ferrari F430 or 288GTO. More drop-dead gorgeous than all other ferraris F-40/50/60 included, aside from maybe a few of the classics. Porsche 997 Turbo with aftermarket wheels (tech art, BBS RS-GT, or Champion Motorsports... something besides the ugly stock wheels) Ruf or Gemballa Porsche (almost ANY of them) Koenigsegg CCR/X Aston Martin Rapide. DB9 and a supercharged Vantage V8 would be tempting, as well. Aston Martin DB4GT Zagato. TVR Sagaris or T440 (Tuscan hardtop) Maserati Birdcage 75th Anniversary concept car. Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted July 12, 2006 Share Posted July 12, 2006 Gotta be honest here. Ain't no car worth giving ol' lefty up for. Jesse Link to comment Share on other sites More sharing options...
Subastew Posted July 12, 2006 Share Posted July 12, 2006 Screw the high priced production cars, let me drive this! Top Fuel - Wikipedia, the free encyclopedia 0-100mph in 0.8 seconds...beat that porsche. Link to comment Share on other sites More sharing options...
-TT- Posted July 12, 2006 Share Posted July 12, 2006 Nissan Skyline GT-R V-Spec II (BNR34) edit:or the 997 Porshce 911 GT2 Link to comment Share on other sites More sharing options...
twisted Posted July 12, 2006 Share Posted July 12, 2006 Gotta be honest here. Ain't no car worth giving ol' lefty up for. Jesse agreed but if all women-kind vanished and thereby leaving the nuts for not much use..i would reluctantly give my left nut for the new 911 turbo Link to comment Share on other sites More sharing options...
Xenonk Posted July 12, 2006 Share Posted July 12, 2006 Gotta be honest here. Ain't no car worth giving ol' lefty up for. Jesse Having uber amounts of sex with Carmen Electra + Jessica Alba + Jessica Simpson + $100,000,000 would be better choice to give up your left nut for.. so I have somewhat of a high standard of what my left nut is worth. Keefe Link to comment Share on other sites More sharing options...
rc0032 Posted July 12, 2006 Share Posted July 12, 2006 ...Jessica Simpson... so I have somewhat of a high standard of what my left nut is worth. You sure Link to comment Share on other sites More sharing options...
tallguylehigh Posted July 12, 2006 Share Posted July 12, 2006 Well, if we are looking at a car to give my left... ya know for, I would pick a Bugatti Royale or the Rolls Royce Silver Ghost, then sell them for 12 million or 50 million respectively. But if I couldnt do that... much more difficult. Something truly timeless, quick and a convertible. Give me a Ferrari 250 California http://budd.bundy.free.fr/les%20vraies/california.jpg Link to comment Share on other sites More sharing options...
05sublegacygt Posted July 13, 2006 Share Posted July 13, 2006 brand new zo6.. i would honestly do it.. this exact 1 Link to comment Share on other sites More sharing options...
Xenonk Posted July 13, 2006 Share Posted July 13, 2006 You sure I didnt say a conversation with, I said uber amounts of sex.. Keefe Link to comment Share on other sites More sharing options...
Gire Posted July 13, 2006 Share Posted July 13, 2006 Give me a Ferrari 250 California http://budd.bundy.free.fr/les%20vraies/california.jpg aahhhhh..... you beat me to it! This Ferrari could be the closest thing to a (multiple) orgasm on wheels. If I was an Italian playboy (or James Bond), I'd be all over a new Lamborghini Murc'. Something about the car just scares the hell out of me... in the best way! Link to comment Share on other sites More sharing options...
godwhomismike Posted July 13, 2006 Share Posted July 13, 2006 I didnt say a conversation with, I said uber amounts of sex.. http://thebosh.com/archives/upload/2006/06/Simpson-Jessica.jpg ehhhhhhhhhhh Link to comment Share on other sites More sharing options...
twisted Posted July 13, 2006 Share Posted July 13, 2006 i will so give my left nut for all of them Link to comment Share on other sites More sharing options...
unobtainium Posted July 13, 2006 Share Posted July 13, 2006 Bristol Cars - HomepageBristol Fighter. Link to comment Share on other sites More sharing options...
zildjiank Posted July 13, 2006 Share Posted July 13, 2006 Realistically...don't quote me here... I don't think I'd be able to enjoy my dream car that much w/o my left nut...No left nut=less testosterone to enjoy my ride... Link to comment Share on other sites More sharing options...
andersoncollectibles Posted July 13, 2006 Share Posted July 13, 2006 I dont have one. So problem solved Children's and Family Photographer http://www.AForgetMeNotMoment.com Link to comment Share on other sites More sharing options...
andrew.anderson Posted July 13, 2006 Share Posted July 13, 2006 I would not give a body part for any car. Link to comment Share on other sites More sharing options...
robinlsb Posted July 13, 2006 Share Posted July 13, 2006 Screw the high priced production cars, let me drive this! Top Fuel - Wikipedia, the free encyclopedia 0-100mph in 0.8 seconds...beat that porsche. About the turn at the end of the main straight..................... "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Subastew Posted July 13, 2006 Share Posted July 13, 2006 About the turn at the end of the main straight..................... I didn't say I wanted to turn. If I want to take turns fast, I'll ride a motorcycle or join NASCAR. hehe However, I still wouldn't want to give up a nut. I'd rather drive a pinto then do that. Link to comment Share on other sites More sharing options...
godwhomismike Posted July 13, 2006 Share Posted July 13, 2006 How about your right nut? I kinda like my left nut more. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted July 13, 2006 Share Posted July 13, 2006 I like my nuts and cars depreciate too much. I'm not gonna be stuck 20yrs down the road with 06 Vette and no left nut. That's just craziness! OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
Xenonk Posted July 13, 2006 Share Posted July 13, 2006 I like my nuts and cars depreciate too much. I'm not gonna be stuck 20yrs down the road with 06 Vette and no left nut. That's just craziness! well, 20 years from now, both will be useless. Keefe Link to comment Share on other sites More sharing options...
godwhomismike Posted July 14, 2006 Share Posted July 14, 2006 well, 20 years from now, both will be useless. :lol: :lol: :lol: :lol: Link to comment Share on other sites More sharing options...
melayout Posted July 14, 2006 Share Posted July 14, 2006 Pagani Zonda F => [ame=http://video.google.com/videoplay?docid=1143312657812574457&q=zonda+f]5th Gear Pagani Zonda F - Google Video[/ame] A true super car. I keed I keeed Link to comment Share on other sites More sharing options...
