16psibrick Posted June 28, 2006 Share Posted June 28, 2006 this set up can definetly be pulled off wtih a LGT sedan, as our well is even bigger...so anyone who want to do stealth with no floor rasiing... just got done with another g35, this time a 04 sedan. the goals are: 1. good sound quality 2. fully stealth trunk install with no floor raising 3. nav and dvd playback capability now, this car is a lot more difficult to pull off a flat floor set up than the coupe.. the coupe has a long wide well running down the entire length of hte trunk, where as the sedan only has a smaller spare tire well offset to the back and passenger side of the trunk. meaning, in order to do NOT raise the floor at all, every single piece of gear has to be contained in the well...something that involves the picking the right equipment and doing the right kind of install so lets get started: anchoring hte signal upfront is the pioneer avic-d2 nav unit in there via the double din conversion kit: http://simplicity.elitecaraudio.org/edisong1.jpg since hte d2 does not have dvd playback capability, a fahrenheit half din dvd player is flush mounted in the upper glove box. its remote eye is located on top of the dash so the unit can be operated with the box closed http://simplicity.elitecaraudio.org/edisong2.jpg here they are working together: http://simplicity.elitecaraudio.org/edisong3.jpg speakers in the G consists of a DLS ultimate Up6 6.5" compnent set upfront, with the midbass in the stock location, albeit sitting in a fiberglassed semi-sealed cup, and the tweeter flushed into the stock kick panels, out back, DLS 426 component coaxials provide sound for the rear passengers. since it was kinda dark i could only get two fuzzy pics of the kicks http://simplicity.elitecaraudio.org/edisong4.jpg http://simplicity.elitecaraudio.org/edisong5.jpg Link to comment Share on other sites More sharing options...
16psibrick Posted June 28, 2006 Author Share Posted June 28, 2006 now here is the trunk, as you can see, in full stealth mode, the floor was not raised even a millimeter, the stock trunk carpet remains to provide a completely stock look: http://simplicity.elitecaraudio.org/edisong6.jpg lifting off this carpet reveals first a simple protective board that covers the spare tire well, with some mesh for air to pass through http://simplicity.elitecaraudio.org/edisong7.jpg here is the heart of the system. a ED 13kv2 is sitting in its flush suede trimed area, and a cover in the back features a raised infinity logo. the rest of hte top cover is finished in black vinyl http://simplicity.elitecaraudio.org/edisong8.jpg http://simplicity.elitecaraudio.org/edisong9.jpg lifting the cover reaveals a DLS CA51 5 channel amp sitting in its own suede lined well, with wires passing through grommits. the sub sends over 50 watts to each interior speaker, and over 300 real world watts to the 13kv2 there is a plexi cover above the well with my logo on it http://simplicity.elitecaraudio.org/edisong10.jpg http://simplicity.elitecaraudio.org/edisong11.jpg http://simplicity.elitecaraudio.org/edisong12.jpg and at night, a flick of a switch throws some white lighting onto the well http://simplicity.elitecaraudio.org/edisong13.jpg and finally, if you are wondering how the sub can possiblly have enough air space, well, a wierd looking semi-circular sub box is used to get about 1 cubic feet, the box sits in the forward half of the spare tire well so there is room for the amp rack behind it http://simplicity.elitecaraudio.org/edisong14.jpg overall, sounds great, and abosltuely no loss of trunk space, i havent had the chance to do this kind of install in this particular kind of trunk well...hopefully iw ill get to do some more in the future Link to comment Share on other sites More sharing options...
PGT Posted June 28, 2006 Share Posted June 28, 2006 nice work as always man!! Link to comment Share on other sites More sharing options...
rao Posted June 28, 2006 Share Posted June 28, 2006 Very nice! Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Legacy05 Posted June 28, 2006 Share Posted June 28, 2006 damn that is nice! Link to comment Share on other sites More sharing options...
Precise Posted June 28, 2006 Share Posted June 28, 2006 i wish you could pimp my ride Link to comment Share on other sites More sharing options...
lucas569 Posted June 28, 2006 Share Posted June 28, 2006 i like how u mounted the tweeter but doesnt it hurt the sound with them pointed at your feet? i would have them at least angled.... or do they swivel? Link to comment Share on other sites More sharing options...
Hanger Posted June 29, 2006 Share Posted June 29, 2006 wow i like this alot!!! ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
fweasel Posted June 29, 2006 Share Posted June 29, 2006 How does the amp vent heat under that plexi? ignore him, he'll go away. Link to comment Share on other sites More sharing options...
16psibrick Posted June 29, 2006 Author Share Posted June 29, 2006 where the tweet is doesnt affect sound at all, this isnt true all tweeters, but through experience i have found that the DLS ultiamte line of speakres work GREAT off axis...and i have had a lot of sucess with this configuation in many cars infact, dls doesnt even provide you with an off axis moutning option for the higher end tweets the amp's well is complelely open on the back end, in the past, with high quality amps, this have been sufficient in getting the heat out as long as the heat has somewhere to go out, it has been fine. my own DLS A5 is under much thicker covering with no problem b Link to comment Share on other sites More sharing options...
lucas569 Posted June 29, 2006 Share Posted June 29, 2006 do you have any links for dls speaker reviews? Link to comment Share on other sites More sharing options...
16psibrick Posted June 29, 2006 Author Share Posted June 29, 2006 um...just do a search, there are some around, its one of thoes brands, like focal, that there are tons of good reviews around THE DLS Audiophiles you can click on the pseakres, scroll to the bottom of each page, some of them have reviews posted Link to comment Share on other sites More sharing options...
scans007 Posted June 29, 2006 Share Posted June 29, 2006 Amazing, always amazing......... My fingers are crossed Link to comment Share on other sites More sharing options...
