kkushner4474 Posted June 23, 2006 Share Posted June 23, 2006 Check engine light Codes read misfire in cylinders 3 and 4 First got this with original spark plugs so I changed them and cleared the codes and received the same codes again so I got new wires and again light is back cleared codes and I received it once more Every time it happens when I am in 5th gear 70 mphs and about 3000 rpms I have spark plugs that are about 3 months old, spark plug wires that are 2 weeks old I have tested my coil pack and everything checks out So what’s wrong? ? SUBARU LEGACY INTERNATIONAL CLUB :: View topic - My never ending problem Link to comment Share on other sites More sharing options...
dplacen Posted June 23, 2006 Share Posted June 23, 2006 I would try another coil pack. Link to comment Share on other sites More sharing options...
kkushner4474 Posted June 23, 2006 Author Share Posted June 23, 2006 i was thinking maybe a faulty fuel injector but that would happen at every gear at 3-4 rpms and not juut 5 i just dont want to spend more money for a coil pack i'm just a poor college student Link to comment Share on other sites More sharing options...
dplacen Posted June 23, 2006 Share Posted June 23, 2006 I have used ones at work but they wont fit the year off your car sorry. Link to comment Share on other sites More sharing options...
kkushner4474 Posted June 24, 2006 Author Share Posted June 24, 2006 the one im having problems with is my 99 Link to comment Share on other sites More sharing options...
Aczwild Posted June 24, 2006 Share Posted June 24, 2006 Go to the auto parts store and first try some injector cleaner (it helped smooth out my tiring '97 engine) and then check your coolant levels every so often to see if it is staying the same, or if you are losing fluid JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
kkushner4474 Posted July 4, 2006 Author Share Posted July 4, 2006 I drove my car down to the shore I held the speedometer at 60, 63, 65, 67, 70, 73, 75, 77, 80 and took it up to 90 for a bit NO Check engine light and it passed that special number of 70 mph and 3000 rpms in 5th After about hour and a half of driving at various speeds from 60 to 85 the check engine light comes on at 70mphs 3000 rpms 5th gear and flashes for 10 secs then goes solid then on the way home from the shore its solid the whole way till about an hour in the light flashes fro another 10 secs and goes back to solid driving in a range of 60 to 70 mphs Link to comment Share on other sites More sharing options...
CarlitoQC Posted July 5, 2006 Share Posted July 5, 2006 Since you already try plugs and wires, you should really go for coil. Look on Ebay there's a seller selling them 30$. Oh BTW I have the same problem as you. I had the CEL last summer and now it's back again, I think it might be caused by humidity, I didn't have a single CEL the whole winter/spring!!! I just bought the coil pack first and I'll see if it fix the problem. Why is it always cyl 3-4!! I thought it was the wiring but I saw that coil pack at 30$ so I jumped on it. My plugs are good (at least they look like)so next step would be NGK wires. So first one to fix it, ready go! oh I've forgot to mention, I saw the CEL comes up when I'm usually 40MPH getting of highway 5th to 4th... very strange, althought, I'm not sure of the pattern... Link to comment Share on other sites More sharing options...
wukindada Posted July 5, 2006 Share Posted July 5, 2006 Coil pack 1st....injectors after that:( Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
CarlitoQC Posted July 5, 2006 Share Posted July 5, 2006 Coil pack 1st....injectors after that:( now you just scared the $#$# out of me!! lol would injectors work better during winter and cold time?? Link to comment Share on other sites More sharing options...
wukindada Posted July 5, 2006 Share Posted July 5, 2006 Should not make a difference..... No need to replace all 4, try one @ a time. By the way, what does the term Cold mean? We had a COOL morning here....73*.......By 1pm ....94* Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
kkushner4474 Posted July 5, 2006 Author Share Posted July 5, 2006 Well I have had this problem since say February and I'm in PA so it gets pretty cold then and pretty humid now. Link to comment Share on other sites More sharing options...
CarlitoQC Posted July 5, 2006 Share Posted July 5, 2006 Cold...cool whatever! I usually speak french see Link to comment Share on other sites More sharing options...
kkushner4474 Posted July 6, 2006 Author Share Posted July 6, 2006 ran codes today at autozone before trying anything else and now im down to just cylinder 3 misfireing so i have another bottle of fuel injector cleaner and going to see how that works out leaning towards a faulty fuel injector Link to comment Share on other sites More sharing options...
kushwa Posted July 11, 2006 Share Posted July 11, 2006 So I cleared my codes after putting in a new fuel filter and drive my car about 2 miles and got a new code Drove up to AutoZone today and have p0507 and p0303 Idle higher than normal and misfire in cylinder 3 Link to comment Share on other sites More sharing options...
