DAVES XTOUTBK Posted June 21, 2006 Share Posted June 21, 2006 Had a guy at the local gas station comment to me that he thought I had a bad motor mount when he was watching my car shake as I started it up. I re-started it, paying attention, and he was right. The front end does wiggle when the motor turns over. I thought that was the way Subaru motors were. Do I have a problem...?????? Dave Link to comment Share on other sites More sharing options...
SBT Posted June 21, 2006 Share Posted June 21, 2006 How much deflection from normal are you talking about? SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DAVES XTOUTBK Posted June 21, 2006 Author Share Posted June 21, 2006 I really don't know what "normal" is.....? Link to comment Share on other sites More sharing options...
brett s Posted June 21, 2006 Share Posted June 21, 2006 The mounts are pretty soft, it'll definitely move around a bit. Link to comment Share on other sites More sharing options...
DAVES XTOUTBK Posted June 21, 2006 Author Share Posted June 21, 2006 The mounts are pretty soft, it'll definitely move around a bit. So are you saying that's pretty normal for the Outback??? Link to comment Share on other sites More sharing options...
SBT Posted June 22, 2006 Share Posted June 22, 2006 Depends how much movement you're talking about. There is a slight engine rock which is common to almost every vehicle on the market. That I wouldn't worry about as it's normal. Does it look like the engine is trying to throw itself out of the engine compartment or does it just rock slightly when you start it up. Is there any bumping noise coming from the engine compartment when you start up from a stop or shift up/down through the gears? If not, then I'd think that everything seems to be normal. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
rao Posted June 22, 2006 Share Posted June 22, 2006 Totally normal. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted June 22, 2006 Share Posted June 22, 2006 Normal- the boxer engine just has more shake to it. Tell him Porsche's do it too and that it's to be expected. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted June 22, 2006 Share Posted June 22, 2006 normal for sure Link to comment Share on other sites More sharing options...
