jp928 Posted November 28, 2006 Share Posted November 28, 2006 IIRC C is for chassis codes (body electrics) and P is for powertrain codes.... jp Link to comment Share on other sites More sharing options...
legacy_y_tu Posted November 28, 2006 Share Posted November 28, 2006 [quote name='jp928']IIRC C is for chassis codes (body electrics) and P is for powertrain codes.... jp[/quote] Good to know, thanks. Link to comment Share on other sites More sharing options...
Garandman Posted November 28, 2006 Share Posted November 28, 2006 [quote name='shane']Thanks mate - I found it. The correct term for this symptom is hesitation under load I believe - stuttering is a symptom some people have with their speech and nothing to with cars. Some people are funny. Gt's only and nothing to do with clutches either, my mistake.[/quote] And, buddy, in the UK I believe the term used is "stammering." You'll also note threads that refer to "studder" which to my knowledge isn't a word in the English language. It's not even in the Urban Dictionary. But nonethless provides a succinct description of the phenomena. It's part of this community. If there were more military and ex-military we would have an acronym, instead. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
legacy_y_tu Posted January 2, 2007 Share Posted January 2, 2007 So I had a CEL the other day. I proceeded to hook upo the connectors, then hit the trip button. I didn't get any codes on the odometer. Confused, I did the test a second time. When the gauges started sweeping I hit the trip button twice instead of once. When I did the odometer read all dashes and the CEL light disappeared. My question is; has anyone done this? It appears I cleared the CEL code even though I didn't see one the first time around. I'm wondering if I stumbled on some new functionality for this connector. I was figuring it was gonna be P2009 again as I've thrown that one not too long ago. Also, this morning car started real hard...... no CEL's popped up.:confused: Any thoughts on this guys? Link to comment Share on other sites More sharing options...
NSFW Posted January 3, 2007 Share Posted January 3, 2007 On my 2005, there are a pair of connectors in the passenger side footwell, right about the ECU, which must be connected for EcuFlash to talk to the ECU. I think those connectors might be the cause for the left-side / right-side confusion earlier in this thread. Anyway, after pulling my ROM with EcuFlash (reading, not writing it), the car didn't start until after a few tries. At least one other person has reported the same thing. Perhaps there's a related issue when using the left-side connectors for the code display trick. (I haven't tried it yet myself though.) Link to comment Share on other sites More sharing options...
GT111 Posted September 27, 2010 Share Posted September 27, 2010 According to the service manual if you re-connect the diag connector by the fuse box under the dash, then press the trip knob during the guage sweep it will tell you if/what codes are present! Excellent. Anyone think they have codes thrown? Wanna try it out? I should probably do it, the stuttering might throw codes. Does this work with the '07 2.5i? Link to comment Share on other sites More sharing options...
frank_ster Posted September 27, 2010 Share Posted September 27, 2010 my connector is left connected all the time. i use it all the time ! and it shows chassis codes and tranny codes also Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
GT111 Posted September 27, 2010 Share Posted September 27, 2010 Thanks. But you have an '05 LGT. I want to know if this works on an '07 2.5i? Link to comment Share on other sites More sharing options...
frank_ster Posted September 27, 2010 Share Posted September 27, 2010 it sould .. try it ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
jton Posted September 27, 2010 Share Posted September 27, 2010 none in my 2.5i. they say it was an 05 thing Link to comment Share on other sites More sharing options...
GT111 Posted September 28, 2010 Share Posted September 28, 2010 I had a very good look on my '07 2.5i and can only find 3 white female connectors, no male connectors. Can anyone confirm if the cluster on the '07 2.5i can be used as an OBD scanner? Link to comment Share on other sites More sharing options...
WolfpactVI Posted November 21, 2010 Share Posted November 21, 2010 I also would like to know if this works on 07 Legacys. I have an 07 Spec.B, and (without removing large pieces of trim under the dashboard) could not locate the described connectors. I have also searched this forum and the internet in general trying to find instructions on how to read CELs on 07 Legacys using the dashboard/odometer. I couldnt find anything at all. Anyone able to post pics of how to do this on an 07? Thanks! Link to comment Share on other sites More sharing options...
WolfpactVI Posted December 16, 2010 Share Posted December 16, 2010 So I found the two ends of the green "test mode connector" as per page EN(H4SO)(diag)-47 of the 2007 FSM. They were under the edge of the floor carpet under the left side of the glove box in the passenger footwell. I plugged them together and turned my key to the ON position (when the gauges light up and do the sweep). Tried various pressing the trip meter in various patterns, but did not get any codes to display. All I got was a weird cycling of the radiator fan. The instructions were for also connecting a scan tool to the OBD port, so that might have something to do with it. Now, I just saw some stuff on page EN(H4SO)(diag)-59 regarding the Malfunction Indicator Light and the test mode connector, with no mention of a scan tool. But in reading through the section I couldnt determine if there was a way to get the codes to display on the trip meter screen. Just got my Tactrix OpenPort 2.0, so I'm going to try ROM Raider's Learning View utility. Would be handy to not need anything but the car to read CEL codes though. If I find anything else useful I'll post it here. Link to comment Share on other sites More sharing options...
