Guest *Jedimaster* Posted September 20, 2004 Share Posted September 20, 2004 So basically you can read codes on the display without having to go to Autozone and rent an IDB scanner? That's great! Link to comment Share on other sites More sharing options...
ADirtyLegacy Posted September 23, 2004 Share Posted September 23, 2004 At the moment I have a CEL, and from reading this thread is seems all I have to do is connect a male and female connectors under the dash and press the trip knob and I should be able to get the code? Hate to sound redundant, just wanna make sure I understand this be4 I go screw something else up! Kenda Link to comment Share on other sites More sharing options...
jim1969 Posted September 24, 2004 Share Posted September 24, 2004 [quote name='GoSix'][quote name='Deer Killer']"Neutral Switch Input Circuit High"[/quote] Hmm....I'm bringing my car into the dealership in a couple weeks to get a clear bra (with the 500 scooby bucks). Would I be able to wait until then, or would this be a more urgent issue?[/quote] What brand of clear bra will you be getting? X-Pel, Rockblocker, Invisa-shield or Stoneguard. Link to comment Share on other sites More sharing options...
GoSix Posted September 24, 2004 Share Posted September 24, 2004 [quote name='jim1969']What brand of clear bra will you be getting? X-Pel, Rockblocker, Invisa-shield or Stoneguard.[/quote] The place that puts on the clear bra prefers to use BSF Clearshield, which is supposed to be thicker than 3M (such as Xpel). They said that if the car is too "curvy," they use the 3M because it is easier to apply. They said that they normally put Clearshield on the Subarus. Give a man a beer, and he'll waste an hour. Teach a man to brew, and he'll waste a lifetime. Link to comment Share on other sites More sharing options...
highwaydrifter Posted October 5, 2004 Share Posted October 5, 2004 haha i have a cel as well actually its my second one... one was open throttle (my bad i will try and stay out of it from now on) the other i have yet to pull.. Link to comment Share on other sites More sharing options...
amason Posted November 19, 2004 Share Posted November 19, 2004 [quote name='GoSix']I did get a couple options on the trip odometer, though: S (toggle on and off) and I (toggle on and off). Does anyone know what those are?[/QUOTE] Sure, they're the toggles for the gauge Sweep, and Incremental illumination. You need one for the other, but I forgot which one. Andy Link to comment Share on other sites More sharing options...
D-2.5-GT Posted September 16, 2005 Share Posted September 16, 2005 This trick does in fact work. I was able to pull a code last night which was the identical code which the dealer pulled this morning. The wires are tucked up by the fuse box. There is a green and while male plug and white female plug up there. Connect the two white female plugs and as the guages sweep, press the trip reset button. The code was in fact displayed on the odometer. Not sure how it would work with multiple error codes, but at least in this case i pulled 1 and was able to find out what it was. Link to comment Share on other sites More sharing options...
f1anatic Posted September 16, 2005 Share Posted September 16, 2005 Yea but those connectors are on the passenger side bro ! You made it seem like it is on the left side. Fuses are on the driver"S side...the diagnostic connector is on the passenger Link to comment Share on other sites More sharing options...
D-2.5-GT Posted September 17, 2005 Share Posted September 17, 2005 [quote name='f1anatic']Yea but those connectors are on the passenger side bro ! You made it seem like it is on the left side. Fuses are on the driver"S side...the diagnostic connector is on the passenger[/QUOTE] You are incorrect my friend. Pop the fuse pannel at the driver's left knee area and you'll find everything you need under the dash. It is tucked up a little in there though. You should see them however. This may not be the same connection which the dealer uses to plug his scan tool in, but i can assure you i pulled a code just 2 days ago by connecting two wires from in the dash on the drivers side only. Link to comment Share on other sites More sharing options...
jp928 Posted November 10, 2005 Share Posted November 10, 2005 aNYBODY KNOW if this stuff works in other market models (AUSDM)? Link to comment Share on other sites More sharing options...
RoundBoy Posted December 13, 2005 Share Posted December 13, 2005 I just can't find these connectors... I seem to have no play in my black cables on the left hand side of the fuse box .. so I can't see any connectors. Anyone have pics ? Yes -> 2005 LGT Link to comment Share on other sites More sharing options...
PhilT Posted December 13, 2005 Share Posted December 13, 2005 You may have to pull a part of the dash down, I did. There are two pairs of connectors, one white, one green taped together. Connect the two white ones only. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
jp928 Posted February 7, 2006 Share Posted February 7, 2006 Having found the 2 wires (black/yellow green/silver fleck in white connectors in AUSDM car) to connect and being able to read the codes (none), if I provoke one as a test (by disconnecting a sensor), how do I clear it? Or will it go away with repeated starts after its fixed? Will it still stay in a log for the dealer to find? thanks, jp Link to comment Share on other sites More sharing options...
D-2.5-GT Posted February 7, 2006 Share Posted February 7, 2006 unhook the battery and pump the brakes. Let it sit for a few minutes. This should clear any code, unless its a valid code, which would most likely come back. Its basically a reset of the system. Link to comment Share on other sites More sharing options...
TYNY Posted April 10, 2006 Share Posted April 10, 2006 subscribe Link to comment Share on other sites More sharing options...
gt_ltd Posted April 11, 2006 Share Posted April 11, 2006 [quote name='Deer Killer']According to the service manual if you re-connect the diag connector by the fuse box under the dash[/quote] is the diag connector located under the side mirrors controllers? This Space For Rent Link to comment Share on other sites More sharing options...
PhilT Posted April 11, 2006 Share Posted April 11, 2006 [quote name='gt_ltd']is the diag connector located under the side mirrors controllers?[/quote] It's in the fuse compartment by your left knee, just above the hood release. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rallispec Posted April 11, 2006 Share Posted April 11, 2006 [quote name='PhilT']It's in the fuse compartment by your left knee, just above the hood release.[/quote] yep... make sure you look around in there -- they were taped up really good with some other wires in my car, made the really hard to see, and even harder to get access too. Link to comment Share on other sites More sharing options...
gt_ltd Posted April 11, 2006 Share Posted April 11, 2006 [quote name='PhilT']It's in the fuse compartment by your left knee, just above the hood release.[/quote] thanks mang. i was looking for the cables in that compartment last nite but gave up since it's too dark and i was exhausted. This Space For Rent Link to comment Share on other sites More sharing options...
PhilT Posted April 11, 2006 Share Posted April 11, 2006 I had to pull the whole dash down a bit to find them, they were taped together with another set of connectors, green ones I think. Winder why the 06 doesn't have them, you think SOA realised we had found them ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
gt_ltd Posted April 11, 2006 Share Posted April 11, 2006 [quote name='PhilT']Winder why the 06 doesn't have them, you think SOA realised we had found them ?[/quote] big brothers are always watching us, but i dont think they mind that we know about this feature... they don't care about us anyway. :( This Space For Rent Link to comment Share on other sites More sharing options...
amason Posted April 25, 2006 Share Posted April 25, 2006 Do ppl leave them connected, or connect and disconnect every time you want to read a code? Thx, Andy Link to comment Share on other sites More sharing options...
D-2.5-GT Posted April 25, 2006 Share Posted April 25, 2006 [quote name='amason']Do ppl leave them connected, or connect and disconnect every time you want to read a code? Thx, Andy[/QUOTE] definetly connect and disconnect. Link to comment Share on other sites More sharing options...
ebpda9 Posted April 26, 2006 Share Posted April 26, 2006 nice. now i need to untie the stereo cables i just ziptied to them Link to comment Share on other sites More sharing options...
legacy_y_tu Posted November 28, 2006 Share Posted November 28, 2006 [quote name='D-2.5-GT'] ............ Not sure how it would work with multiple error codes, but at least in this case i pulled 1 and was able to find out what it was.[/quote] If you have more than one code you can find out by pressing the trip button repeatedly and it will display 3 P codes. I cycled mine repeatedly and got 3 P codes and one C code. Don't ask me what a C code is though :confused:. Display looked like: P2009 P---- P---- P---- C---- I only had the one code , and it's off to the dealer to get the Tumble generator valve replaced for me:confused:. Link to comment Share on other sites More sharing options...
