camber Posted May 31, 2006 Share Posted May 31, 2006 2000 LGT Some quick questions.... Is it ok to use Redline 75w-90ns for the front diff and tranny? Redline 75w-90 for the rear diff? And what quantities? For the current LGT(2005+) it's 3.7 qts for the tranny & front diff and 0.8 qts for back.... Link to comment Share on other sites More sharing options...
bluesuby Posted June 2, 2006 Share Posted June 2, 2006 I know the NS is correct for the front. I used Mobil1 in the rear because it's easier to just squeeze it in the filler from their bottle. Link to comment Share on other sites More sharing options...
camber Posted June 3, 2006 Author Share Posted June 3, 2006 I figured as much. Just wanted to confirm and hear comments about the Redline NS in older revision suby 5MT. Link to comment Share on other sites More sharing options...
rougeben83 Posted June 3, 2006 Share Posted June 3, 2006 Older subbies only need 3.5 qts. I slightly overfilled mine with Redline MT-90, thinking it was 3.7 Rear diff I used Redline 75w90 gear oil, about .7qts or so. Link to comment Share on other sites More sharing options...
camber Posted June 3, 2006 Author Share Posted June 3, 2006 Thanks for the info. I'll keep that in mind. How do fluidyou like your MT-90 over stock(vavoline IIRC)? Link to comment Share on other sites More sharing options...
B2.5GT Posted June 4, 2006 Share Posted June 4, 2006 If you have a 5 speed trany I will recomend using 75W90 gear oil for smother shifting. Link to comment Share on other sites More sharing options...
