wheatleya Posted May 8, 2006 Share Posted May 8, 2006 Can we get a good list of after market Oil filters for the LGT and their part numbers. And also which ones people prefer. I know there might be a little debate, but I think this would be a big help for people, becuase of the problems with Oil Filters in the past. Link to comment Share on other sites More sharing options...
NutBucket Posted May 8, 2006 Share Posted May 8, 2006 OEM Japanese filters for me; Toyo-Roki. Link to comment Share on other sites More sharing options...
wukindada Posted May 8, 2006 Share Posted May 8, 2006 K&N for me......removing the oil filter has Never been easier HP 1008 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
outahere Posted May 9, 2006 Share Posted May 9, 2006 OEM Japanese filters for me; Toyo-Roki. Me too! Link to comment Share on other sites More sharing options...
mccorry Posted May 9, 2006 Share Posted May 9, 2006 I use a Purolator oil filter.... I'll post the # later as I can't remember it. Edit... is is a 14460 filter. Link to comment Share on other sites More sharing options...
Paradiso Posted May 9, 2006 Share Posted May 9, 2006 Bosch, Mobil 1 , NAPA Gold - all excellent, all easily available Link to comment Share on other sites More sharing options...
brad32 Posted May 10, 2006 Share Posted May 10, 2006 Purolator Pure One Link to comment Share on other sites More sharing options...
NutBucket Posted May 10, 2006 Share Posted May 10, 2006 Bosch, Mobil 1 , NAPA Gold - all excellent, all easily available Bosch aren't what they used to be...just a heads up. Link to comment Share on other sites More sharing options...
JBLU24 Posted May 10, 2006 Share Posted May 10, 2006 the black oem filters (the toyo-roki made in japan posted above) i have also used a mobil1 and the k&n 1008 i like all 3 and dont plan on trying a 4th...... Link to comment Share on other sites More sharing options...
mach_six Posted May 10, 2006 Share Posted May 10, 2006 I use Walmart Supertech filters in my cars. They are made by Champion Labs, same one that makes it for STP and Bosch. They filter up to 20 microns P/N ST6607, I bought the earlier versions and the new ones out are shorter for the same reason why the new OE are shorter. I change my oil regularly so I don't see a problem here and I read on BITOG forums that people have good results with their oil analysis using that filter. Now I won't use Fram on the other hand. Link to comment Share on other sites More sharing options...
franklin Posted May 10, 2006 Share Posted May 10, 2006 Purolator Pure One +1:) Link to comment Share on other sites More sharing options...
deadeye Posted May 13, 2006 Share Posted May 13, 2006 I have had a couple of Turbo Subies.. The few times I have an Oil chg at the dealer--when I get home & c heck the dip-stick it is WAY over the full mark.. Any of you have that prob??. I have seen a few posts on here where they actually drain and/or siphon out oil to get to the full mark on the stick.. When I chg it myself-I put in four (4) qt's then adda little after warm up to reach the full mark. Is it a BIG deal or not ???? Deadeye:confused: Link to comment Share on other sites More sharing options...
wukindada Posted May 13, 2006 Share Posted May 13, 2006 Deadeye.......still waiting on those avatar pics;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
edmundu Posted May 13, 2006 Share Posted May 13, 2006 I use Walmart Supertech filters in my cars. They are made by Champion Labs, same one that makes it for STP and Bosch. They filter up to 20 microns P/N ST6607, I bought the earlier versions and the new ones out are shorter for the same reason why the new OE are shorter.... I like the ST filter's for the same reasons....Also, I use the ST7317, as it is 0.5" longer, and holds a touch more oil. I have done 2 UOA's with them, and the reports come out no different than using the Toyo Roki's. I have a few of both on the shelf, but once my OEM supply runs out, I'm just going to use the ST's, they are 1/3 of the price! Link to comment Share on other sites More sharing options...
showbo Posted May 13, 2006 Share Posted May 13, 2006 Wix is arguebly(sp?) the best oil filter on the market. Napa filters are made by Wix if you can't find the actual name. Link to comment Share on other sites More sharing options...
deadeye Posted May 13, 2006 Share Posted May 13, 2006 wukindada---i NEED YOUR e-mAIL ADDY... dEADEYE Link to comment Share on other sites More sharing options...
wukindada Posted May 14, 2006 Share Posted May 14, 2006 Check your PM Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
