niskyne Posted May 8, 2006 Share Posted May 8, 2006 For those of you who have mounted your boost guage on the steering column, how did you do it? I'm thinking of using the thick foam double sided tape and tape it on, but I don't know if that would look good or not. Also, it's probably going to be a little harder to get it to stick since the guage is round so there won't be as much contact. So i'm just trying to get other ideas of how to mount it. Thanks everyone! Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 8, 2006 Share Posted May 8, 2006 That or screw it in with self tapping screws from the top, there is no other way without breaking stuff. Don't ask me how I know. Link to comment Share on other sites More sharing options...
CreoSTi Posted May 8, 2006 Share Posted May 8, 2006 My 45mm Omori is mounted in this on the steering column (from j-spectuning.com); http://www.j-spectuning.com/images/single_pod_only1.JPG What size is your gauge? If it's larger than 45mm, perhaps you can find a mount here; http://www.egauges.com/ -Mike- Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 8, 2006 Share Posted May 8, 2006 How did you mount yours creo? Link to comment Share on other sites More sharing options...
CreoSTi Posted May 8, 2006 Share Posted May 8, 2006 http://www.mcnproductions.com/lgt/interior/omori2.jpg -Mike- Link to comment Share on other sites More sharing options...
PeterJMC Posted May 8, 2006 Share Posted May 8, 2006 Looks good Mike! What idiot lights does it block? Not sure if that's the CEL light I see or not. Link to comment Share on other sites More sharing options...
CreoSTi Posted May 8, 2006 Share Posted May 8, 2006 Here's another pic; http://www.mcnproductions.com/lgt/interior/omori1.jpg The only thing it blocks from my vantage point, is the illuminated "Legacy" that's right behind the gauge/pod. -Mike- Link to comment Share on other sites More sharing options...
jim1969 Posted May 8, 2006 Share Posted May 8, 2006 ^did you have to remove the steering cover? Link to comment Share on other sites More sharing options...
niskyne Posted May 8, 2006 Author Share Posted May 8, 2006 What size is your gauge? If it's larger than 45mm, perhaps you can find a mount here; http://www.egauges.com/ -Mike- It's a 52mm Megan Racing gauge. I'm going to check that site to try to find something. That looks awesome! Pretty much exactly what i'm going to try to do Thanks Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 9, 2006 Share Posted May 9, 2006 ^did you have to remove the steering cover? I broke mine doing it, mines on the other side though? Red or white. Link to comment Share on other sites More sharing options...
CreoSTi Posted May 9, 2006 Share Posted May 9, 2006 ^did you have to remove the steering cover? Yes, search on here for dropping the steering column down, as this is the easiest way (only 2 nuts/bolts hold it up). -Mike- Link to comment Share on other sites More sharing options...
Meltdown07 Posted May 9, 2006 Share Posted May 9, 2006 Mine's on the other side too. Doesnt block anything, and I love it. Go Cardinals! Link to comment Share on other sites More sharing options...
jim malach Posted May 9, 2006 Share Posted May 9, 2006 I thought I seen steering wheel colums where it holds two gauges? Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 9, 2006 Share Posted May 9, 2006 For the WRX. Link to comment Share on other sites More sharing options...
Meltdown07 Posted May 9, 2006 Share Posted May 9, 2006 I thought I seen steering wheel colums where it holds two gauges? Yes those exist. However, they only allow 52 or 60mm gauges. I didnt want something that big. I didnt want my view to be obstructed at all. Plus I just like the look of the 45mm Omori. Go Cardinals! Link to comment Share on other sites More sharing options...
PeterJMC Posted May 9, 2006 Share Posted May 9, 2006 Is the brightness adjustable on that gauge? Link to comment Share on other sites More sharing options...
PeterJMC Posted May 9, 2006 Share Posted May 9, 2006 I thought I seen steering wheel colums where it holds two gauges? Perrin... http://www.perrinperformance.com/products/legacy/gauge_pod.htm or you could just buy two of those. Link to comment Share on other sites More sharing options...
Meltdown07 Posted May 9, 2006 Share Posted May 9, 2006 Is the brightness adjustable on that gauge? Pretty sure you can, i'll play with it tomorrow and report back. Edit: Yep you can, just tried it. Just turn all the knobs down, and adjust them all up at the same amount to still get the white color, but at a dimmer level, took a fair amount of tweaking, but it was possible. I'll see if I can get you a pic tomorrow. Go Cardinals! Link to comment Share on other sites More sharing options...
ronburgandy21 Posted May 9, 2006 Share Posted May 9, 2006 niskyne, I had, what I thought was strong double sided tape holding mine on. It would only last like a week before it would break loose. I decided to bolt it on. No issues now! Link to comment Share on other sites More sharing options...
ZinFreak Posted May 30, 2006 Share Posted May 30, 2006 For those of you who have mounted your boost guage on the steering column, how did you do it? I'm thinking of using the thick foam double sided tape and tape it on, but I don't know if that would look good or not. Also, it's probably going to be a little harder to get it to stick since the guage is round so there won't be as much contact. So i'm just trying to get other ideas of how to mount it. Thanks everyone! Here's my walkthrough on how to install the Omori 45mm on the steering column. Click here for the walkthrough.... Be well. -Zin 06 LGT LTD GRP 5MT 07 FXT LTD OBP 4EAT Link to comment Share on other sites More sharing options...
godwhomismike Posted June 11, 2006 Share Posted June 11, 2006 Here's another pic; http://www.mcnproductions.com/lgt/interior/omori1.jpg The only thing it blocks from my vantage point, is the illuminated "Legacy" that's right behind the gauge/pod. -Mike- I like this option, but am concerned with blocking the gear I'm in when I'm in manual mode in my 5EAT. How much for the housing, I might get the gauge elsewhere. Link to comment Share on other sites More sharing options...
Meltdown07 Posted June 11, 2006 Share Posted June 11, 2006 I like this option, but am concerned with blocking the gear I'm in when I'm in manual mode in my 5EAT. How much for the housing, I might get the gauge elsewhere. You dont have to put it on that side. I also have a 5EAT and did mine on the other. Check out the pics of my install here: http://legacygt.com/forums/showthread.php?t=34090 Go Cardinals! Link to comment Share on other sites More sharing options...
jim1969 Posted June 12, 2006 Share Posted June 12, 2006 I wonder how a 52mm gauge would look in the right hand position. Link to comment Share on other sites More sharing options...
