TheRaven Posted March 29, 2006 Share Posted March 29, 2006 I got my Cobb AP last week and flashed to stage 1, 91. I've put about 200 miles on the car since with nothing but positive things to say about it. But this morning, I drove the car to the airport and it started making a new noise. It sounds like the intake "woosh" you get by adding a Perrin panel filter and removing the intake silencer (which I've done). The weird thing is that the intake noise comes from the right front of the car. This is a similiar noise but it seems to be coming from the back-center or back-left of the engine compartment. It's very consistent and happens adjacent to the intake woosh on the throttle curve but continues as I apply power all the way up to ~5000rpm. So, am I hearing the blow-off valve? If this is totally normal then I'll drop it, but I wanted to make sure that there wasn't something wrong as it started rather abruptly is very noticeable. I not totally sure, but the car also felt slightly sluggish today. This may have been the headwind on the way to the airport though. I think I'll hold on declaring that until I drive it some more. Any other people out there with identical setups that could chime in? Thanks in advance, -Erik Link to comment Share on other sites More sharing options...
psucaptainkickass Posted March 29, 2006 Share Posted March 29, 2006 I think this is normal. I have always heard a woosh....stage 1 or no stage 1. Maybe you are cued into it more now that you added something new and you are keen to new noises. I like to call it a scream instead of a woosh. It is one of the best noises I have ever heard. :-D Link to comment Share on other sites More sharing options...
emlevins Posted March 29, 2006 Share Posted March 29, 2006 Sounds like it may be your filter. When I installed my AVO panel filter, I noticed the same thing (btw - I didn't care for it and went back to the stock filter). 05 SWP Legacy GT Limited (aka "Pearl")- 5MT AP - Stage 2 Protuned (238/284) - wife driven 07 BMW 335xi Link to comment Share on other sites More sharing options...
boostsr20 Posted March 29, 2006 Share Posted March 29, 2006 Does the car still feel the same? If it has less power I'd be inclined to say you have a boost leak and you may want ot check the I/C tabs to make sure they are all in tact. If it feels the same then you may just be hearing some of the intake noise/wastegate fluttering. Link to comment Share on other sites More sharing options...
Beanboy Posted March 30, 2006 Share Posted March 30, 2006 What was the air temp? -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
TheRaven Posted March 30, 2006 Author Share Posted March 30, 2006 So, I've read on this forum about the potential intake noise. I actually like it too. This sound was different though. While it was related to the woosh of the intake it was closer to the cabin. The ambient temp was 52 F. When I get back, the first thing I'll check are the IC tabs and vacuum hoses near the IC. I just hope I didn't blow a gasket on the manifold or DP. I'll also reassess the power of the car and try to determine if it has lost power. I really need to spring for an OBD scanner so I can watch the boost. Has anyone ever experienced this on a stage I? I've heard of similiar stuff happening on a highly modded stage II, but never with just a flash and panel filter. One other question, could this noise be caused by a partially stuck waste gate? Link to comment Share on other sites More sharing options...
boostsr20 Posted March 31, 2006 Share Posted March 31, 2006 Have someone watch your Realtime boost readings while you drive . Try to note what boost you get where then post them up. People will be able to tell you if its normal. I doubt the wastegate is stuck though. Link to comment Share on other sites More sharing options...
TheRaven Posted April 1, 2006 Author Share Posted April 1, 2006 Ok, I just got back and checked for loose hoses, etc. Nothing. The noise persists and the car is definitely not as quick. I hooked up my AP and watched the RT boost. in 3rd @ 4000rpm I'm at 10.5psi max, and 4th @ 4000rpm is 12.5psi max. Idle boost is -7 to -8psi. Temp was 55 F. Elevation 5500ft. This is starting to look more like I have a boost leak. It's not a hose (I think), any ideas where to look next? Link to comment Share on other sites More sharing options...
TheRaven Posted April 1, 2006 Author Share Posted April 1, 2006 Ok, took a better look at things this morning, removed the engine cover and IC and discovered the hose clamp on the hose going from the IC to the intake was popped off slightly (on the intake side). I reattached everything and the noise stopped and RT boost @ 4000rpm in 4th was 15.3psi peak. The car felt like it did before the noise. What difference 3psi makes! Also, while I was under there, I replaced the t-fitting under the IC with a brass t-fitting w/barbs, and added mini-hose clamps to the other vacuum lines. One thing I was a little pissed off about is that I checked the torque on the bolts holding the IC down and the IC hose clamps. Bolts on the turbo side were 1/2 the spec torque, as was the hose clamp nut on the side of the IC that was still on. Either Subaru isn't following their own specs or they loosened themselves somehow. I've never really looked closely at the IC on my XT, but after pulling it out I was surprised how flimsy it looks. At least everything is fine now, on to other mods until something else breaks! Thanks for the suggestions, this forum really rocks! Thanks, -Erik Link to comment Share on other sites More sharing options...
boostsr20 Posted April 2, 2006 Share Posted April 2, 2006 Glad you got it cleared up! Link to comment Share on other sites More sharing options...
