RaceComp Engineering Posted May 10, 2006 Share Posted May 10, 2006 Cobb now has reinforcement brackets available.... Link to comment Share on other sites More sharing options...
gt_ltd Posted May 10, 2006 Share Posted May 10, 2006 just tack on a piece of metal from end to end and then just use another L-bracket and bolt it up to the subframe.. it's a real DIY.. If you really want me to get a shop to do it and sell it as a kit, I'll need to see a lot of interest for them.. otherwise, stuff like this can be made at any performance shop that can weld some pieces of metal for ya. group buy anyone? This Space For Rent Link to comment Share on other sites More sharing options...
hal9e3 Posted May 19, 2006 Share Posted May 19, 2006 Here's how to do an RSB: http://www.comptechusa.com/store/140100.html Link to comment Share on other sites More sharing options...
PGT Posted May 19, 2006 Share Posted May 19, 2006 Here's how to do an RSB on a non-AWD car: http://www.comptechusa.com/store/140100.html Link to comment Share on other sites More sharing options...
hal9e3 Posted May 19, 2006 Share Posted May 19, 2006 Not sure why you edited my post, but I'm assuming you're implying that there would be clearance issues with the rear diff/axles. I don't see any reason a SB/TB combo couldn't be engineered to overcome this problem. Cusco makes a rear brace for example, and the RSB could be mounted to that. Link to comment Share on other sites More sharing options...
PGT Posted May 19, 2006 Share Posted May 19, 2006 I didn't edit your post. I quoted it and added an important bit of info that was missing. As for clearances, it's tight under there and anything like you suggest would have to go in back of the diff. You can't mount the swaybar to the braces...different place altogether Link to comment Share on other sites More sharing options...
hal9e3 Posted May 19, 2006 Share Posted May 19, 2006 I say edit, you say quote and add - potAto, potato. Someone out there should be able to engineer a solution to this issue for our cars. Link to comment Share on other sites More sharing options...
