bhogan414 Posted March 8, 2006 Share Posted March 8, 2006 I was running a four channel amp off of the stock stereo in my 05 LGT, and the other day I got in my car, and the stereo and clock were on before I put the key in. I then realized that although everything seemed to be working just fine, there was no sound. I took it into the place that installed it and they told me that the amp had blown and had sent the stereo into protect mode, which was why it was staying on, and that I needed a new amp. Now I don't know that much about the details of these things, but I don't understand how the amp could just blow like that, and from my understanding there is no feedback between the amp and the stereo unit and my worry is that it was some sort of install issue, and they are trying to escape responsibiliy. Anyone that could shed some light on the issue for me would be greatly appreciated, it could be that I just don't know what the hell I am talking about, I don't know. Link to comment Share on other sites More sharing options...
wcbjr Posted March 8, 2006 Share Posted March 8, 2006 How high was the gain on the amp? What ohm load were the speakers presenting the amp? I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
PGT Posted March 8, 2006 Share Posted March 8, 2006 check the fuse? was it a used amp? warranty? Wukinada has a sweet Rockford amp for sale cheap. Link to comment Share on other sites More sharing options...
Boulderguy Posted March 8, 2006 Share Posted March 8, 2006 Sent the stereo into protect mode? I call BS on that. Maybe it sent the amp into protect mode. Can you elaborate on exactly what equipment & what speakers it's driving? What shop are you using (in Boulder I presume)? Link to comment Share on other sites More sharing options...
bhogan414 Posted March 8, 2006 Author Share Posted March 8, 2006 The whole system is a bit old, I have pieced it together over the years, but it is an Alpine amp running 55 watts rms, powering a pair of Focal polykevlar components in the front and Eclipse point sources in the rear. I don't know the specific ohms, but the gain was set pretty solidly in the middle, I definitely wasn't maxing it out. The amp is definitely still getting power, the status light on it is now showing red, which according to the manual, indicates that the circuit is "abnormal." The shop is Cartoys here in Boulder. Link to comment Share on other sites More sharing options...
wukindada Posted March 8, 2006 Share Posted March 8, 2006 My amp is still avail...... 100 plus shipping Rockford amp..... when Rockford was a great company..... Alot more power than what you had;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Boulderguy Posted March 8, 2006 Share Posted March 8, 2006 Hmm. It’s always a roll of the dice when playing with used gear, but that’s no reason for it to fail. So the amp’s in protect mode, not the CD player, right? Three reasons why that happens – improper install, improper use or broken gear. Cartoys is pretty good, so assume the install’s OK for now. It’s a 4 channel amp running four speakers so it’s an appropriate use. That leaves speakers, speaker wiring & the amp itself. First thing I’d check is the speakers, that’s usually the problem. Disconnect all the negative connectors on the amp speaker terminals, then re-start the car. Still in protect mode? Disconnect the RCA’s too, then re-start again. Also check the amp fuses, the onboard fuse & the one by the battery. If still no joy it’s probably new amp time. Cartoys has a kick-ass Eclipse 4-channel on sale for about $280 or get the same one on Ebay for $200. If any of the above fixes the problem you’ve got a short in the wiring, the shop should cover it under their install warranty. Outside chance it’s a bad speaker, but wiring is more likely. Link to comment Share on other sites More sharing options...
wukindada Posted March 8, 2006 Share Posted March 8, 2006 ^ Or you could get my Fosgate amp & blow away the eclipse for less than half the price;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
bhogan414 Posted March 9, 2006 Author Share Posted March 9, 2006 Excellent, thank you for the tips. Of course it is snowing now, and without a garage, I guess it will just have to wait before I can check everything, then maybe I will have to consider a new amp. I will let you know wukindada. Link to comment Share on other sites More sharing options...
