bluechipbmw Posted February 17, 2006 Share Posted February 17, 2006 Swift: Front: 20-25mm drop Rear: 10-15mm drop Front: K=42.5N/mm Rear: K=66N/mm $500 Ion: Front: 30mm drop Rear: 25mm drop Front (progressive): K=40N/mm (first inch of compression) K=52N/mm (by second inch of compression) Rear: K=67N/mm About $400 Hey Hans - What contributes to the measure of the drop? Is it the actual measure in height of the spring? If there were 2 different springs side by side and both measured the same height can they have a different drop? Link to comment Share on other sites More sharing options...
mccorry Posted February 17, 2006 Share Posted February 17, 2006 Hey Hans - What contributes to the measure of the drop? Is it the actual measure in height of the spring? If there were 2 different springs side by side and both measured the same height can they have a different drop? Yes... the loading and rate will affect the drop. Link to comment Share on other sites More sharing options...
Scooter Posted February 18, 2006 Share Posted February 18, 2006 ^^^ A LOT. You can't compare springs by their unloaded dimensions. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
PeterJMC Posted February 18, 2006 Share Posted February 18, 2006 Swift: Front: 20-25mm drop Rear: 10-15mm drop Front: K=42.5N/mm Rear: K=66N/mm $500 Ion: Front: 30mm drop Rear: 25mm drop Front (progressive): K=40N/mm (first inch of compression) K=52N/mm (by second inch of compression) Rear: K=67N/mm About $400 Have this info for the JDM STI Legacy GT Sedan (MT) Pinks? Link to comment Share on other sites More sharing options...
bosco Posted February 20, 2006 Share Posted February 20, 2006 check the web site tein.com, they have all the spec., bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
crash Posted February 21, 2006 Share Posted February 21, 2006 Swift: Front: 20-25mm drop Rear: 10-15mm drop Front: K=42.5N/mm Rear: K=66N/mm $500 Ion: Front: 30mm drop Rear: 25mm drop Front (progressive): K=40N/mm (first inch of compression) K=52N/mm (by second inch of compression) Rear: K=67N/mm About $400 Just wanted to make a note on this... Swifts can be had for MUCH cheaper than $500 now. Just check the vendor for-sale forum! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 21, 2006 Share Posted February 21, 2006 I got some JDM spec B take-offs. front about 12 - 20 mm drop rear about 0 - 8 mm drop rates are 4.0 front vs 3.5 OEM 6.0 rear vs 5.5 OEM (Not 100% sure of the numbers, but very close) Very cheap. http://www.legacygt.com/forums/showthread.php?t=27472 Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
PhoenixMrx2 Posted February 22, 2006 Share Posted February 22, 2006 OK... From the pictures Ive seen it looks like the swifts drop the car more... but according to Han'sGT's info the ions are actually more of a drop. Which actually lowers the car more? Link to comment Share on other sites More sharing options...
HansGT Posted February 22, 2006 Share Posted February 22, 2006 OK... From the pictures Ive seen it looks like the swifts drop the car more... but according to Han'sGT's info the ions are actually more of a drop. Which actually lowers the car more? the numbers for the iON springs I got from Jack at iON. the swifts i got from racecompengineerings site. http://www.racecompengineering.com/legacy.htm Link to comment Share on other sites More sharing options...
iON Performance Posted February 22, 2006 Share Posted February 22, 2006 PhoenixMrx2 - The amount of lowering that our Sport Spec springs lower the car are based on using USDM OEM struts. The Swifts could've been measured while on different struts (ie: non USDM OEM). Link to comment Share on other sites More sharing options...
