Legasee Posted March 28, 2006 Share Posted March 28, 2006 dam...I gotta finish mine...got so many things I wanna do with the car In Taiwan now... Link to comment Share on other sites More sharing options...
H2OSB Posted March 28, 2006 Share Posted March 28, 2006 home depot gutter guard. five strips for $0.01:icon_bigg That's the plastic stuff? When I was contemplating doing my own DYI grill, I looked at gutter guard. I saw both thin wire metal stuff and black plastic stuff. I ended up buying a section of aluminum screen door repair. It was a perfect mesh (or would have been after it was painted black), however, I it wasn't wide enough. H2OSB Link to comment Share on other sites More sharing options...
itsme Posted March 28, 2006 Share Posted March 28, 2006 I used the metal one. I primed it, then I painted it with black bumper paint. In the morning I will take closeup and take it out and show pix of the back. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
lookslikeanevo Posted March 28, 2006 Share Posted March 28, 2006 looks real good!!! what did you use to hold the grill in? Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted March 29, 2006 Author Share Posted March 29, 2006 Badged! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 29, 2006 Share Posted March 29, 2006 I'm worried about stone chips on mine- do you guys think using high temp engine paint would be more durable? Link to comment Share on other sites More sharing options...
Vahkil Posted March 29, 2006 Share Posted March 29, 2006 I'm worried about stone chips on mine- do you guys think using high temp engine paint would be more durable? The bare aluminum looks pretty good on silver cars. Any other color and I would go with a black paint. I first painted my mesh with 500deg engine paint. I had it on there for about a week of some highway driving and didn't notice any chips. I decided I liked the unfinished silver look better though and redid it. In the painted case, judging by the damage the entire front of my car takes, I'd expect to have to repaint (or replace entirely) the mesh once a year at most since I doubt any can spray paint will cure hard enough to deter rocks. My unfinished aluminum has oxidized (and just plain gotten dirty) over the 8 months its been on the car. I may replace it every so often as well. (Can't argue spending $1 each time it needs to be replaced). Link to comment Share on other sites More sharing options...
itsme Posted March 29, 2006 Share Posted March 29, 2006 Here is a close up of the grill. It shows the sides, the bottom, top and the down part show where I filled in with bundo and how close the paint (gunmetal metallic) matches stock paint. I only paint the inside of the grill. The lower grill is just cut to lenght and dropped in the sides hold it in place. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
itsme Posted March 29, 2006 Share Posted March 29, 2006 For the mounting of the mesh I used tie wraps. On the bottom edge of the grill I used part of the tabs that were left over when I cut out the center to keep the grill in place. To mount the emblem I used epoxy to bind a bolt to the back. I tried to add 4 bolts but, I could never could get the emblem to line up. So I went with one bolt with double sided tape on both sides of the mesh. I used bundo to fill all the cut out. When you sand the middle of the grill use a sanding block it will make the job much easier. Any other questions or pix you need let me know. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
lookslikeanevo Posted March 29, 2006 Share Posted March 29, 2006 For the mounting of the mesh I used tie wraps. On the bottom edge of the grill I used part of the tabs that were left over when I cut out the center to keep the grill in place. To mount the emblem I used epoxy to bind a bolt to the back. I tried to add 4 bolts but, I could never could get the emblem to line up. So I went with one bolt with double sided tape on both sides of the mesh. I used bundo to fill all the cut out. When you sand the middle of the grill use a sanding block it will make the job much easier. Any other questions or pix you need let me know. looks real good man, real good, im not that good with bondo tho... Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
scans007 Posted March 29, 2006 Share Posted March 29, 2006 You guys all using your "stock" badge or did you dig up JDM ones. On my old grill the badge I had was equiped with 2 screw points......man I should've kept that.....it's the hardest thing to find. Link to comment Share on other sites More sharing options...
Vahkil Posted March 29, 2006 Share Posted March 29, 2006 ^I yanked the stock badge off and used that. Link to comment Share on other sites More sharing options...
itsme Posted March 29, 2006 Share Posted March 29, 2006 I took my time and pulled off the stock one. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Mblock66 Posted March 29, 2006 Share Posted March 29, 2006 I have a stock from emblem still if that is what you mean. I am not using it now either Link to comment Share on other sites More sharing options...
imprezarsx Posted November 30, 2006 Share Posted November 30, 2006 Wanna trade emblem? I got a genuine Subaru LL emblem that I can trade for your stock Subaru one off the grille. Pardon the crappy camera phone picture. http://img.photobucket.com/albums/v93/oister/subaru/03-13-06_1402.jpg The emblem is "L T" for Legacy Turbo. It's on my 93 JDM Legacy GT also. The BG5 chassis as some of you may know it by. It's a twin turbo legacy. Sorry to resurect the thread, but I'm looking at doing this grill mod to my 06LGT Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 17, 2006 Share Posted December 17, 2006 scribe it Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted December 18, 2006 Share Posted December 18, 2006 I have a stock from emblem still if that is what you mean. I am not using it now either I realize the above message is 9 months old, but do you still have that badge, Mblock? I have a grille that looks like "itsme's" grille. (an original Subastyle grille, on Subastyle's old car, no less. ) I have a red and chrome STI badge in it, and I am thinking I want to add the subie oval back in. But it didn't come along when I bought the car from subastyle... A spare one that noone is using would be cool! I'd buy it. I've already asked the nearest subie dealer, but not gotten any response about it, or any of the other parts I want. Link to comment Share on other sites More sharing options...
itsme Posted December 18, 2006 Share Posted December 18, 2006 They have a more recent theard. If forgot the name but I know it had "DYI" in the name. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 18, 2006 Share Posted December 18, 2006 They have a more recent theard. If forgot the name but I know it had "DYI" in the name. This one? http://legacygt.com/forums/showthread.php?t=29392&highlight=DIY+grille Link to comment Share on other sites More sharing options...
itsme Posted December 19, 2006 Share Posted December 19, 2006 yes Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
rawfish Posted March 22, 2007 Share Posted March 22, 2007 my next project fur sure!!!! Link to comment Share on other sites More sharing options...
diamondgraymetallic21 Posted June 23, 2007 Share Posted June 23, 2007 Well two comments from me after just doing mine. First off, I attached the mesh by using clear liquid nails. That way I wouldn't have to drill or find spots to attach it, I did this on a previous car and it held for years. Just another option since I hadn't seen it mentioned. Second, for those of you that painted the chrome section, did you have any problems with the chrome beginning to "bubble" after you sanded it so the primer and paint would adhere better? Mine began to bubble and it seems to almost be impossible to get rid of/smoothed out. Link to comment Share on other sites More sharing options...
unbekabal Posted September 16, 2007 Share Posted September 16, 2007 Badged! looks great! i'm doing this to my 05 LGT! Umm i hope you noticed you left off the fog light bezels? Link to comment Share on other sites More sharing options...
