low_suby_wagon Posted January 6, 2006 Share Posted January 6, 2006 Well, its finally time for new clutch in my wagon. I have never done it before, but am well inclined mechanically. I was wondering if anyone has any tips on the process. The one thing that bothers me is that it looks like I must drop the exaust to pull down the tranny. By the way, she is a 2wd suby. Any tips would be helpful. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 6, 2006 Share Posted January 6, 2006 2wd Suby!!! That's blasphamy!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
rc0032 Posted January 6, 2006 Share Posted January 6, 2006 Scoobymods has a good walk through. wiener stop being a wiener http://www.v6performance.net/forums/images/smilies/furious.gif Link to comment Share on other sites More sharing options...
low_suby_wagon Posted January 6, 2006 Author Share Posted January 6, 2006 2wd Suby!!! That's blasphamy!!! when I want a low rider w/ fast response I take the wagon, when I want my real awd LGT I ride the sedan. When you buy used, you take what you can get. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 6, 2006 Share Posted January 6, 2006 wiener stop being a wiener [/img] +1 when I want a low rider w/ fast response I take the wagon, when I want my real awd LGT I ride the sedan. When you buy used, you take what you can get. Today 07:42 PM I'm with ya brudda Link to comment Share on other sites More sharing options...
PGT Posted January 6, 2006 Share Posted January 6, 2006 on a scale of 1 to 10, how would you rank replacing the clutch on the '05 LGT's?? Anybody? Link to comment Share on other sites More sharing options...
low_suby_wagon Posted January 9, 2006 Author Share Posted January 9, 2006 Well, I just finished the install, went with a exedy stage 2, very nice! On a scale of 1-10 of hardness compared to other clutch installs, this one was about an 8. Yes the exaust had to come down. (side tip, buy your bolts for the exaust from the dealer before the install, I couldn't find them anywhere) I ended up making new ones from parts from the help! department in autozone. Not the best but will make due until my header install. I am very happy with the improved shift perfomance, who would have known 3rd gear chirp? Link to comment Share on other sites More sharing options...
mccorry Posted January 9, 2006 Share Posted January 9, 2006 What are the step that you need to do? 1.) pull exhaust2.) pull driveshaft ???3.) unbolt tranny bellhousing from block?4.) remove front half shafts ???5.) Slide transmission back and down ?? etc, etc, etc..... Link to comment Share on other sites More sharing options...
low_suby_wagon Posted January 9, 2006 Author Share Posted January 9, 2006 Well it's kinda drawn out but here goes: remove negative battery cable, remove air intake tube and hoses (makes it easier to see tranny bolts), remove clutch cable & neutral cable, remove positive cable off starter and remove, jack up and go below, remove the plug for the o2 sensor, remove exaust at exaust manifolds 3 bolts per mainfold, remove spring bolts at cat, unhook exaust from back tranny mount, remove 2 bottom bolts off tranny (there is only a total of 4 major tranny bolts 17mm), back up top, remove 2 upper tranny bolts, remove the dogbone like trans mount, and its bracket, remove spedo cable, remove plug for reverse sensor, take a chain or something and support motor from rear, i used a pry bar wedged over my strut bar, back down below, take a jack and strap it to the middle of tranny, remove shift linkage there are 2 different bolts for the two pieces, remove the bolts that hold the trans mount towards the back of the tranny i think its a total of 4 bolts all 17mm, then jack down and pry gently off engine, slow and easy it will come off. a few good tips, use locktite on all internal bolts for the flywheel, pressure plate and clutch, make sure you replace all bearings, pilot, and throw out, grease the pins on the tranny to make install easier, its a bit*h to get out, make it easy to get in, get a buddy to help, its easier to steady the tranny out and in, don't forget to readjust the clutch pedal on install either with a cable tranny or bleed the hydraulic, and don't skimp on parts the torque gained with less slippage during shifts is reason enough to want to go with a racing clutch. next upgrade 4 me is STI trans mounts if the fit. Link to comment Share on other sites More sharing options...
rao Posted January 9, 2006 Share Posted January 9, 2006 The 05+ Legacy's do not have roll pins holding the front axles to the tranny, which makes life a lot easier. There is a circlip inside of the tranny that holds the axle in place and you just pop the axles out. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mccorry Posted January 9, 2006 Share Posted January 9, 2006 Thanks for the info, guys.... So... you don't have to do anything with the front suspension to get the drive axles out? Link to comment Share on other sites More sharing options...
low_suby_wagon Posted January 9, 2006 Author Share Posted January 9, 2006 Damn, thats the one thing I forgot to mention was to remove the axles, yes in the old ones you pull the roll pins, I haven't done an 05 yet. It wasn't hard at all to pull those pins. Link to comment Share on other sites More sharing options...
