IcyFridge Posted July 7 Share Posted July 7 I noticed my 24 sport with 3k miles always has some camber in the rear. Is this normal? Link to comment Share on other sites More sharing options...
silverton Posted July 7 Share Posted July 7 yup Link to comment Share on other sites More sharing options...
IcyFridge Posted July 9 Author Share Posted July 9 On 7/7/2024 at 9:59 AM, silverton said: yup Thanks! I had the same on my Crosstrek, but the Legacy is so low in the back so I wasn't sure if it was "normal" or not. Link to comment Share on other sites More sharing options...
fuzzysoul Posted July 10 Share Posted July 10 (edited) OK, I know that it's typical. But is it desirable? Or is it just a result of the Legacy being a lowered Outback? Anybody look into a camber adjustment? Edited July 10 by fuzzysoul Link to comment Share on other sites More sharing options...
silverton Posted July 10 Share Posted July 10 spec is -1.5* +/- .45*. For a car that's driven on the street a majority of the time, it's a good thing. Due to weight transfer while turning you get more stability and less tire wear with a little bit of negative camber in the rear. Link to comment Share on other sites More sharing options...
IcyFridge Posted July 10 Author Share Posted July 10 1 minute ago, silverton said: spec is -1.5* +/- .45*. For a car that's driven on the street a majority of the time, it's a good thing. Due to weight transfer while turning you get more stability and less tire wear with a little bit of negative camber in the rear. Perfect info. I noticed my Sport is one of the most planted vehicles I’ve driven on the road. Link to comment Share on other sites More sharing options...
