Painless Posted April 6 Share Posted April 6 Greetings all, I'm running into an oddity that has me confused. I'm installing my old Aukey dashcam from my '19 Legacy into my new '24 Legacy using the fuse-tap. Powers-up and operates normally with ACC power. However, once I start the car, no power (all other car features operating normally). Double checked camera. Swapped camera with a known good camera. Tried a few different F/B Panel fuse locations (No. 29, No. 34, No. 15, No. 2). Has anyone hardwired their dashcam install to the F/B Fuse Panel? If so... Which fuse did you tap into? Which camera are you using? Thanks in advance! Link to comment Share on other sites More sharing options...
dohturdima Posted April 6 Share Posted April 6 Don't know if this will help or not in your situation, as I did not install my dash cam myself but had a shop that I used for a while install it (they said that used a mirrortap and used a wiring kit that I purchased along with my camera). My dual dash cam and the accompanying wiring kit. There is an install thread on SubaruOutback forum that may help you find the correct fuses. Link to comment Share on other sites More sharing options...
