Scottydunno Posted February 23 Share Posted February 23 I picked up a set of 02 tgv housings for my top feed conversion. These were deleted with an aftermarket aluminum plug kit. I have the end plates removed along with the plugs. The issue I'm having is the center of the housing whee the shaft runs through. The plug isn't coming out at all. Does it matter which way it comes out? Is it threaded in? Thoughts??? Link to comment Share on other sites More sharing options...
rhino6303 Posted February 24 Share Posted February 24 Pictures? 1 Link to comment Share on other sites More sharing options...
Scottydunno Posted February 25 Author Share Posted February 25 Here's the pictures of what I'm working with. It was an actual kit as you can see by the last picture. The rubber shaft seals are still in the housings. The first 2 show what I'm trying to remove. Link to comment Share on other sites More sharing options...
KZJonny Posted February 25 Share Posted February 25 1 hour ago, Scottydunno said: Here's the pictures of what I'm working with. It was an actual kit as you can see by the last picture. The rubber shaft seals are still in the housings. The first 2 show what I'm trying to remove. Looks like it was just driven in then staked on both sides…? I would assume it can be driven out, from the looks, but I suppose there is some risk in that. Maybe an adhesive on that pin, so baking in an oven for a while to break it down might help? 1 Link to comment Share on other sites More sharing options...
rhino6303 Posted February 25 Share Posted February 25 Yeah. That appears to just be an aluminum shaft pressed in. I imagine is was an interference fit or has some loctite so a little heat should help. 1 Link to comment Share on other sites More sharing options...
Scottydunno Posted February 26 Author Share Posted February 26 Thanx guys. Looks like propane torch and some pounding... hopefully it'll be easy.. 1 Link to comment Share on other sites More sharing options...
