intro Posted November 12, 2023 Share Posted November 12, 2023 Thanks! Link to comment Share on other sites More sharing options...
KZJonny Posted November 13, 2023 Share Posted November 13, 2023 Why were they removed? If they weren't causing a problem and the valve cover gasket was good/not leaking, then you could reuse everthing. They usually all come in the same kit, gasket and bolt sleeves... If you had to replace the gasket, good bet the rubber in those is also getting tired. Worst case, just throw them back in and keep an eye on them for leaks. They are not a "one time use" part, really... Link to comment Share on other sites More sharing options...
