JeffA Posted November 8, 2023 Share Posted November 8, 2023 Hi everyone. I recently did head gaskets on my 2007 Legacy GT wagon. I have one part that I have no idea where it came from. Any ideas? I have looked through all the online subaru parts diagrams and I dont see it anywhere. Any help is much appreciated. Link to comment Share on other sites More sharing options...
Code Posted November 8, 2023 Share Posted November 8, 2023 This is purely from memory but I’ve seen that before. Looks like it may be the bracket that keeps the alternator clocked? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JeffA Posted November 9, 2023 Author Share Posted November 9, 2023 I dont think it goes to the alternator. I think you might be thinking on the lock nut on the pivot bolt. It has tabs so the nut doesnt turn. This part is much bigger. 3-inches across by 3-inches the other way. The tabs are about an inch long each. I think it helps brace a pipe, or a hose or cable (the white clip on there). But, I cant see anywhere it may have come from. Link to comment Share on other sites More sharing options...
KZJonny Posted November 9, 2023 Share Posted November 9, 2023 Just a guess…. On the transmission? Holds the wiring for the harness? Been a bit since I’ve gone that deep into the engine bay. But that parts looks annoyingly familiar. Link to comment Share on other sites More sharing options...
silverton Posted November 9, 2023 Share Posted November 9, 2023 It might go on one of the top corner bolts of the timing cover. since it's held in by what looks like a single 10mm bolt and holds one wire, you're not going to miss this bracket. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted November 9, 2023 Share Posted November 9, 2023 I looked at a couple part diagrams, but couldn’t figure it out for sure EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Code Posted November 9, 2023 Share Posted November 9, 2023 (edited) @msprank will settle this once and for all Edited November 9, 2023 by Code "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JeffA Posted November 9, 2023 Author Share Posted November 9, 2023 Yeah, I dont see anywhere on the trans bellhousing or the timning cover where it could go. But, I might be overlooking it. I know it's probably not super critical, but it bugs me to have "extra parts" after a project. The subie engineers thought it was a good idea to have it, otherwise they wouldnt have made the part. Link to comment Share on other sites More sharing options...
KZJonny Posted November 10, 2023 Share Posted November 10, 2023 Well…. They also thought it was a good idea to put a catalytic converter in an up pipe, and filter screens in hard to access oil supply banjo bolts…. 1 Link to comment Share on other sites More sharing options...
silverton Posted November 10, 2023 Share Posted November 10, 2023 (edited) whoops Edited November 11, 2023 by silverton Link to comment Share on other sites More sharing options...
KZJonny Posted November 10, 2023 Share Posted November 10, 2023 1 minute ago, silverton said: I'm surprised that bolt broke at 13ft/lb. that's only 5nm over spec. 13ftlb = 17nm, spec is 12nm. just for the record subaru wants you to do two passes of 12nm starting at the top going clockwise, saabaru on the other hand wants one pass of 8nm and a second pass of 12nm. Did you mean to post this to the broken water pump bolt thread by chance? 1 Link to comment Share on other sites More sharing options...
JeffA Posted November 11, 2023 Author Share Posted November 11, 2023 @KZJonny you have a point there! Im sure its not a huge deal, its just good to know. ...For peace of mind. Then I can decide to install or not. 1 Link to comment Share on other sites More sharing options...
