m sprank Posted June 27, 2023 Share Posted June 27, 2023 Re-creating this thread as requested. Originally posted here: After a few requests from members on how the fuel rails run I decided to take some pix. I dont run the OEM rails, so I laid them out with the manifold and tried to display how they run and connect to the manifold. I also tried to label the hoses and fittings you will find. You can swap injectors without removing the manifold completely. It is not the easiest, but can be done. Hopefully these pix help members understand what they are up against and maybe what goes where when putting it back together. First set of pix. Details of the fuel rail and then sitting with the manifold. 1 Link to comment Share on other sites More sharing options...
m sprank Posted June 27, 2023 Author Share Posted June 27, 2023 Details of the manifold and connections. Then how the FPR goes together. Not a whole lot to it. But when it is under the manifold it can be confusing. Any questions just post them up or shoot me a PM. Hope this helps. -Mike 1 Link to comment Share on other sites More sharing options...
Enlight Posted June 28, 2023 Share Posted June 28, 2023 Nobody here has seen OEM fuel rails that clean in 18 years 1 2 muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
KZJonny Posted June 28, 2023 Share Posted June 28, 2023 45 minutes ago, Enlight said: Nobody here has seen OEM fuel rails that clean in 18 years I wish! Seeing @jaylew’s super shiny fuel rails has got me either: -spending more money on my GT for a new set, or -sanding back and painting the old ones that are in my basement and doing the swap. *le sigh* Link to comment Share on other sites More sharing options...
Pleides Posted June 28, 2023 Share Posted June 28, 2023 Now do the guide where you can get rid of the inevitable CEL caused by switching to deleted TGVs after doing the conversion and find out that Cobb can no longer do that for you Link to comment Share on other sites More sharing options...
Enlight Posted June 28, 2023 Share Posted June 28, 2023 I switched to the 02-05 WRX TGV's which are top feed but use the same motor+ sensor as 05-06 LGT, at least according to iWire. 2 1 muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
