pduncan1963 Posted May 5, 2023 Share Posted May 5, 2023 Hi folks. Have a 2023 Legacy Premium which has the same lose ride as a 2015 legacy I previously had. Ended up installing a 20mm anti sway bar on it which really improved the handling. https://www.bamwholesaleparts.com/oem-parts/subaru-stabilizer-bar-20451va000?origin=pla&gclid=Cj0KCQjw0tKiBhC6ARIsAAOXutnu2lDtSgMTBlcpQRdbAbdvxIgvsXV5KOHK59fTN75KalVLQOZCAOsaAs2qEALw_wcB Anyone else out there that have upgraded thier sway bar on this generation Legacy? 1 1 Link to comment Share on other sites More sharing options...
silverton Posted May 5, 2023 Share Posted May 5, 2023 What's the diameter of the stock one? Link to comment Share on other sites More sharing options...
pduncan1963 Posted May 6, 2023 Author Share Posted May 6, 2023 18 was on the 2015. No sure on 2023 Link to comment Share on other sites More sharing options...
fuzzysoul Posted May 7, 2023 Share Posted May 7, 2023 This Content Is Relevant To My Interests According to the very imprecise measuring I did on my '21 Touring, it has a 19mm rear sway bar. So, Suby is using the last gen sway bar, even on the "new" platform? Huh. Lot cheaper than the Whiteline part... Link to comment Share on other sites More sharing options...
avk Posted June 8, 2023 Share Posted June 8, 2023 Great information. Was it also necessary to replace the bushings? The matching part number is 20464VA000. Link to comment Share on other sites More sharing options...
dohturdima Posted June 13, 2023 Share Posted June 13, 2023 On 6/7/2023 at 11:07 PM, avk said: Great information. Was it also necessary to replace the bushings? The matching part number is 20464VA000. Would like to know this as well (new bushing?) as whether a sway-compatible bracket, links etc were also needed or did the stock ones work somehow? Link to comment Share on other sites More sharing options...
