Dreamnara8282 Posted April 29, 2023 Share Posted April 29, 2023 so upgraded to VF52 and there is are a few leaks i cannot pin point? any thoughts advice? i checked all bolts again today and only thing i can think of is possibly the missing gaskets?? Link to comment Share on other sites More sharing options...
KZJonny Posted May 1, 2023 Share Posted May 1, 2023 Assuming you mean vaccum/boost leaks, maybe oil? Details will help. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 1, 2023 Share Posted May 1, 2023 Can you provide more details? Any other changes to support the VF-52 like fuel system upgrades, exhaust, tune, etc? If you are missing gaskets, that would definitely cause a leak. Link to comment Share on other sites More sharing options...
MitchRoyce Posted May 1, 2023 Share Posted May 1, 2023 First things first, it's important to figure out where those leaks are coming from. Have you checked your oil cooler and turbo gaskets? Those can be common culprits when it comes to oil leaks. It's also possible that you might need to replace some worn out seals or o-rings. Make sure to thoroughly inspect all of your hoses and connections, as those can also be potential sources of leaks. And don't forget to top off your fluids before you hit the road! Link to comment Share on other sites More sharing options...
