Trunk Lighting
  • 1 month later...
  • 2 weeks later...
  • 7 months later...
My installation using roughriduz suggestion. I used the center structure as it was straight and close proximity to the socket (the LED strip is rigid). Cleaned the beam first before using the adhesive strip. Threaded the connector through the cage.
I like the idea of a light bar, but something like that would almost certainly get wrecked in my trunk (assuming Murphy is in full effect when I put thing into/take them out of the trunk) - I ended up going with one of the vleds 14 LED 194 bulbs - very bright (rated at 90 lumens - I also used them for the lights on the underside of the door cards).  Would have loved to use one of the 26 LED ones, but I didn't think it would fit under the little grating for the fixture
