relative4 Posted April 12, 2023 Share Posted April 12, 2023 After driving tonight, I noticed a strong fuel smell coming from the left underside of the car, below the left rear door. Haven't yet had a chance to get under there and pull the plastic. Once I do, what are common culprits that I can expect to find? Link to comment Share on other sites More sharing options...
KZJonny Posted April 12, 2023 Share Posted April 12, 2023 LHS? I would start by looking at fuel lines probably. Shouldn’t be much to leak below/around the door… I’d think fuel must be running along something and dripping off on the left. Fuel tank seams are also a common failure point. Hoe full was the tank when you were driving/smelled gas? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2023 Share Posted April 12, 2023 I believe the Evap canister is in that area. You should be able to find a post on here about that area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
