motorbreath Posted March 27, 2023 Share Posted March 27, 2023 I have been suspicious of my MAP sensor readings since I had my 5th gen e-tuned last year. The readings fluctuate constantly, even while maintaining a steady engine RPM and throttle input. Before I spend the $$$ on a new MAP sensor, I am going through all of the hoses and searching for a boost leak. The obvious first thing to do was to replace the MAP sensor filter and associated vacuum hoses...which seems to have had a noticeable affect on the stability of the MAP readings! This might just be my imagination, but a super cheap thing to do, especially since I am not using the OEM shaped vacuum hoses (see the zip tie!). 2 1 Link to comment Share on other sites More sharing options...
ToolTime Posted June 13, 2023 Share Posted June 13, 2023 I just came across this and it seems like an amazing idea for our decade old cars. Have you tried cleaning the MAP sensor too? Link to comment Share on other sites More sharing options...
motorbreath Posted June 13, 2023 Author Share Posted June 13, 2023 I assumed that the original filter kept it clean and was getting clogged, didn't want to risk cleaning the sensor. It seems to be working fine now, so I think I'll leave it alone since I have a laundry list of other stuff to fix! 1 Link to comment Share on other sites More sharing options...
