59ctd Posted February 24, 2023 Share Posted February 24, 2023 My 09 LGT has a very small coolant leak somewhere that I have not figured out yet. I can't see a leak anywhere but most times when I get the car back from a drive into the shop after a minute or five I can smell it. What coolant lines or other things are under the lower left corner of the TMIC? This seems likely where it is as the smell seems to be strongest around here. Link to comment Share on other sites More sharing options...
cheeseenlo Posted February 24, 2023 Share Posted February 24, 2023 @59ctdCheck the two hoses coming from the turbo overflow tank. #2 and #3 in the below diagram. I have a slight weep/leak coming from hose #3 at the connection to the overflow and I smell coolant all the time. This might be what you're experiencing as well. 1 Link to comment Share on other sites More sharing options...
tysparks81 Posted February 24, 2023 Share Posted February 24, 2023 There is a lower coolant hose attached to your turbo, very hard to get to without removing the downpipe and pulling the turbo off. You can pull up your coolant reservoir to the left of your arrow and see if there are any leaks in any of the lines or even a crack in the reservoir. You may need to squeeze the lines as it may be a pin hole leak or cracked line which only sprays when there is increased pressure/load on the system. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
59ctd Posted February 24, 2023 Author Share Posted February 24, 2023 That certainly seems like exactly where it is coming from. I'll have my son pickup or order both those hoses while he is at work today. Link to comment Share on other sites More sharing options...
59ctd Posted February 24, 2023 Author Share Posted February 24, 2023 Thanks I will check that as well when I have the coolant reservoir off. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2023 Share Posted February 24, 2023 Make sure you have coolant to replace what you'll loose. Prestone works well. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
59ctd Posted March 27, 2023 Author Share Posted March 27, 2023 Finally got my 09 LGT coolant leak fixed. Turned out it was a tiny leak at the top radiator hose connection to the engine. My bad the hose clamp was partially over the AL neck rib/bump. Took 3+ years to start leaking. Anyways, I did replace the three smaller hoses around the turbo as well. The one down on the side with the heat shield was hard to get a pliers on the bottom clamp not much room there between the valve cover and subframe. Long nose bent needle nose pliers did the trick. I'm leaving the bottom cover off for a bit to drive it in spring rain and clean off the blue coolant that seems to be everywhere on the bottom of the engine. While my car has been out of commission I've been driving my mom's 06 3.0R Outback sedan which I kinda prefer over the LGT. Same generation legacy/outback but the engines and transmissions are worlds different. 3.0 H6 is so smooth and the older 5EAT shifts nice and firmly 3 Link to comment Share on other sites More sharing options...
cheeseenlo Posted March 28, 2023 Share Posted March 28, 2023 16 hours ago, 59ctd said: Finally got my 09 LGT coolant leak fixed. Turned out it was a tiny leak at the top radiator hose connection to the engine. My bad the hose clamp was partially over the AL neck rib/bump. Took 3+ years to start leaking. Anyways, I did replace the three smaller hoses around the turbo as well. The one down on the side with the heat shield was hard to get a pliers on the bottom clamp not much room there between the valve cover and subframe. Long nose bent needle nose pliers did the trick. I'm leaving the bottom cover off for a bit to drive it in spring rain and clean off the blue coolant that seems to be everywhere on the bottom of the engine. While my car has been out of commission I've been driving my mom's 06 3.0R Outback sedan which I kinda prefer over the LGT. Same generation legacy/outback but the engines and transmissions are worlds different. 3.0 H6 is so smooth and the older 5EAT shifts nice and firmly @59ctdNice work! How difficult was hose #3 from the expansion tank? I should address that sometime before the summer. Link to comment Share on other sites More sharing options...
59ctd Posted March 28, 2023 Author Share Posted March 28, 2023 3 hours ago, cheeseenlo said: @59ctdNice work! How difficult was hose #3 from the expansion tank? I should address that sometime before the summer. Hose #3 was a tricky one but it is certainly doable without disassembling everything. Obviously the expansion tank needs to come off. I used a set of 11" long needle nose pliers. I bought a set that has straight, 45* and 90* angled ends and the 90* one was the ticket to get to the hose clamp down in front of the TMIC. 1 Link to comment Share on other sites More sharing options...
NORULZleggy Posted March 29, 2023 Share Posted March 29, 2023 I think I have this same problem on my 06 LGT, glad I came across this. Link to comment Share on other sites More sharing options...
