mikecsti Posted February 14 Share Posted February 14 I have a 2000 Subaru legacy L wagon with a 5 speed. I was having a starting issue some times. I would turn the key and I would hear the relay click and turn the key and nothing. The voltage at the batter was 12.0 to 12.2. Some times I would hear a wine as it started/grid. So I new it was the starter. Plus it would have a problems starting in the morning, when it was dark or at night. It seemed to be fine during the day. Got a new starter and installed it and cleaned all the terminals. Started right up and starts faster then ever before. I guess the start was weak also. That was a week ago. and has been starting fine. I went out this morning to start he car. Cold and dark out. turn the key and I get a click click click, like a dead battery sound. different then before. I checked the voltage and it was 12.0 and then I turned on the heads and other lights and everything was bright and fine. Tried it 4 time and the same thing. Had to go to work so just got a ride. What would it be now? The car runs fine and has no warning lights on. Alternator was replayed 3 years ago, about 12k battery was replayed 5 years ago, about 20k stater replaced a week ago, 200 miles any help would be great, thanks Link to comment Share on other sites More sharing options...
silverton Posted February 14 Share Posted February 14 resting voltage of 12..12.2 is not a good fully charged battery. a resting voltage of 12.2 is only about halfway charged. ideally you want 12.6 to 13v. Charge the battery and check your cable connections and go from there! Link to comment Share on other sites More sharing options...
mikecsti Posted February 14 Author Share Posted February 14 I should of gave a little more detail. I did not check it with a voltage meter. I will later when I get home. I have a Bluetooth that is plugged in to the accessory port and it says the voltage. So I know it reads a little now that at the battery. Battery connects are tight and all cleaned because I just did that when I did the starter. I know when the car started I'm getting the 14.2 to 14.5 voltages out of the port. If I had time I was going to connect my jump pack this morning but I was so pissed I was like f.. it. Maybe I'm over thinking it and its the battery going. Link to comment Share on other sites More sharing options...
silverton Posted February 14 Share Posted February 14 14.2-14.5 while running is a good indication your alternator is doing its job. Link to comment Share on other sites More sharing options...
doublechaz Posted February 15 Share Posted February 15 5 years and 12.0 volts indicates that the battery is used up. 1 Link to comment Share on other sites More sharing options...
blops Posted November 16 Share Posted November 16 Mine does the same thing. Battery seems to be very weak, and this happens sometimes on cold mornings. If I hold the key for a while, sometimes up to 20 seconds, it finally starts. It can take a few tries as well. Could be something with the fuel system in cold weather maybe? Link to comment Share on other sites More sharing options...
