shralp Posted February 3, 2023 Share Posted February 3, 2023 (edited) Finally making some headway on my winter checklist with the track car. I've been wanting to pull the carpets for awhile and with Santa bringing me a Cool-Shirt system, it was the perfect time to yank them so I could have a good base to mount on. Leaving the drivers seat footwell as is for now until I can source a good heel rest so it doesn't throw off my pedal to floor spacing. Also took the time to gut most of the heavy tar insulation, (everywhere you see grey). It was a bitch but a heat gun and some techniques I figured out made it somewhat tolerable. Carpet and insulation out lightened me up 35lbs. Discovered holes in the rear pass floorboard that were miraculously located just where I wanted to mount the Cool-Shirt bracket. Even sized up right for M8 riv-nuts Got my Setrab Oil cooler mounted up. Again, shocked to discover that 3 of 4 mounting points were exactly where I wanted the cooler and I was able to use the front rad support bolts that were already there to mount. Once the cooler was in, had the lines built, routed and connected to the sandwich plate at Surgeline in Portland to ensure it would be good to go. Also had them swap in a Fluid Dampr pulley. Got my V.2 brake ducts from RooDucts re-installed as well. A few more boxes to check and I'll be ready for the season. Edited February 3, 2023 by shralp 2 1 Link to comment Share on other sites More sharing options...
Underdog Posted February 3, 2023 Share Posted February 3, 2023 Looking great! That tar insulation must have been a PAIN - I’ve only removed small areas and it sucked. How much weight do you figure it saved? The Crimson Dynamo Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 3, 2023 Share Posted February 3, 2023 Second that, that’s an impressive job 1 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
seanyb505 Posted February 3, 2023 Share Posted February 3, 2023 Meanwhile I'm sitting here hoping I can wash my car this weekend. 2 Link to comment Share on other sites More sharing options...
shralp Posted February 3, 2023 Author Share Posted February 3, 2023 3 hours ago, Underdog said: Looking great! That tar insulation must have been a PAIN - I’ve only removed small areas and it sucked. How much weight do you figure it saved? The total weight out of the car was 35 lbs and it looked to be about 50/50 between the tar insulation and the weight of the carpet. Will probably drop another 10 lbs once I pull the drivers footwell carpet and the insulation underneath. There is also tar insulation under each seat that I need to yank out at some point as well. 1 Link to comment Share on other sites More sharing options...
legacybt Posted May 17, 2023 Share Posted May 17, 2023 What model Setrab is that? Looks like a great fit Link to comment Share on other sites More sharing options...
shralp Posted May 17, 2023 Author Share Posted May 17, 2023 14 hours ago, legacybt said: What model Setrab is that? Looks like a great fit its a Series 9 20 row. Yes, the fit is great! Link to comment Share on other sites More sharing options...
legacybt Posted May 17, 2023 Share Posted May 17, 2023 Thanks! I had expected the Series 6 19 row but good to hear we can fit a bit more area under there. Link to comment Share on other sites More sharing options...
