toad77 Posted January 15, 2023 Share Posted January 15, 2023 This might be the wrong forum, but I could use some expert help. I am the original owner and considering selling my 05 LGT Limited 5MT. It's almost entirely stock with 115k miles on the clock. Mostly stock because the only thing I did was swapped the radio/HVAC out for JDM controls and a Pioneer head unit. What would be a reasonable range for private sale? Link to comment Share on other sites More sharing options...
BoozeRS05 Posted January 16, 2023 Share Posted January 16, 2023 Btw $4k to $12k based on the info given 3 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Infosecdad Posted January 16, 2023 Share Posted January 16, 2023 A lot can depend on your location and maintenance status. That will help with recommendations. 1 Link to comment Share on other sites More sharing options...
Max Capacity Posted January 16, 2023 Share Posted January 16, 2023 I would guess between 6-8000 is a more real number. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Febreze Mee Posted January 16, 2023 Share Posted January 16, 2023 4 hours ago, BoozeRS05 said: Btw $4k to $12k based on the info given LOL Yes, not much info has been given. Exterior color (OEM paint color name)? Interior color? Maintenance history? Accident history? Condition of the interior/exterior? Wagon or sedan? Your profile says sedan, but it doesn't hurt to confirm. 2 MILKRUN - Click Here Link to comment Share on other sites More sharing options...
toad77 Posted January 16, 2023 Author Share Posted January 16, 2023 (edited) I appreciate everyone's reply, even if I didn't have a ton of information in my original post. Exterior Color: OBP Interior Color: Black Current mileage: 114123 miles Location: Tampa, FL I just pulled everything I kept from the services I paid for, but I didn't regularly record when I did my own oil changes. Here's my maintenance history. 06 JAN 2023 @ 114123 miles Oil change Belt change PCV valve RH valve cover gasket, half-moons, spark plug gaskets 2 hoses off RH valve cover Spark plugs 07 FEB 2022 @ 110759 miles Diagnose smoke and smell coming from passenger side Replaced turbo coolant outlet hose 12 OCT 2021 @ 109483 miles Oil change 25 SEP 2021 Installed JDM dual zone AV panel Installed Pioneer DMH-1770NEX head unit & backup camera ND-BC8 4 SEP 2021 @~109000 miles Replaced shifter bushing Replaced gear shift CP joint 18 AUG 2020 @ 107003 miles Replaced radiator 17 AUG 2020 @ 106983 miles Replaced upper coolant hose 03 JUL 2020 @ 106872 miles Oil change Airbag inflator recall LH valve cover gaskets, tube seals, half-moons, and oil cooler gasket 10 JUN 2020 Battery replaced 21 JUN 2018 @ 103061 miles Brake fluid exchange Complete injector service 14 APR 2018 @ 102693 miles Replaced tires: 4 Potenza RE980AS Alignment 01 MAR 2018 @ 102244 miles Performed combustion test to see if internal failure of coolant system. Not experiencing blow by No coolant leaks visible at pressure Bled coolant system of air Oil change 17 AUG 2016 @ 100211 miles Timing belt, idlers, tensioners Water pump and thermostat 08 JUN 2016 @ 99653 miles Airbag inflator recall 09 MAY 2016 @ 99502 miles Oil change 13 OCT 2015 Spark plugs 18 NOV 2014 @ 97169 miles Left axle seal replaced Topped off transmission fluid 14 NOV 2014 @ 97095 miles Replaced power steering pump, power steering fluid flush Front and rear differential fluid service 02 SEP 2014 @ 95500 miles Brake pipe corrosion recall performed 13 MAR 2013 @ 78341 miles Front left and right axle assemblies replaced 14 SEP 2012 @ 72203 Clutch assembly replaced 23 FEB 2012 @ New tires Coolant service 04 FEB 2012 @ 65701 miles Front and rear brake service 22 JUL 2008 @ 29668 miles Oil change 28 JUN 2008 @ 27337 miles Oil change Coolant service Brake fluid Mount new tires 18 APR 2007 @ 16208 miles Oil change Fan relay recall 25 MAR 2006 @ 7708 miles Oil change 22 JUL 2005 @ 11 miles Purchased new from Rally Subaru, Windsor Locks, CT Edited January 16, 2023 by toad77 1 Link to comment Share on other sites More sharing options...
BoozeRS05 Posted January 16, 2023 Share Posted January 16, 2023 That’s a solid maintenance history, and depending on condition I’d guess you’re toward the upper range of the estimates. Pending interior and exterior hopefully not being sun damaged. No rust could be a huge plus for an enthusiast. Up north or west you’d probably have a nice easy sale. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
