59ctd Posted January 9 Share Posted January 9 (edited) My 09 LGT is starting to show a very thin line of rust that is super straight right above the windshield on the brim of the painted body. I don't think they would have made the roof with a seam right here but let me know if there is. Ruling out a metal seam as the cause of the rust the only other cause that makes sense is that the Safelite technician caused the damage to the paint when he used his tool to cut the rubber seal/edging when he took the old window out back in 2021. It is hard to see in the pic but the line goes all the way across from side to side. My son and I tried to fix it with touch up paint but that is not working and it is still rusting through. I'll be visiting a Safelite location tomorrow but am unsure what recourse, if any, I might have. Edited January 10 by 59ctd fix pic Link to comment Share on other sites More sharing options...
Pleides Posted January 10 Share Posted January 10 My car has spent its entire life away from salt and anywhere east of NE Washington. The only spot of rust anywhere on the car is in the windshield area and, for me, is only visible with the windshield removed. Your picture doesn't show up, just FYI. Link to comment Share on other sites More sharing options...
blackobxt Posted January 10 Share Posted January 10 (edited) It’s likely from a windshield guy cutting the paint. Better have that fixed now otherwise it gets pretty difficult, it’s probably pretty rotten closer to the windshield. Safelight likely has canned excuses on tap for this exact scenario and will probably politely tell you to kick rocks. Edited January 10 by blackobxt Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 10 Share Posted January 10 yeah you have a 2009. Going back is not going to do much. It could be the age of the car they might say or something else. I would not waste my time. But GL Link to comment Share on other sites More sharing options...
59ctd Posted January 10 Author Share Posted January 10 I visited the local Safelite this morning and all of their techs looked at it and said it is highly likely their fault and they will cover the repairs for me under their "as long as you own the car" warranty. Got an estimate from my local body shop that does decent work. Just shy of $3,000 to disassemble, sandblast and new tricoat SWP from A pillars, entire roof, down the D pillars and the rear quarters too since it is all one contiguous surface. The Safelite I visited this morning was not where the tech 1.5 yrs ago worked out of so he transferred the repair estimate to the owner of the Safelite in Rochester MN. They were a bit shocked how high the estimate was but the way I look at it is Safelite has their warranty they stand behind and the body shop guys need to do it right so they can stand behind their work as well. I'll need to wait for the snow to be gone here in MN since the body shop sandblaster is an outside thing and doesn't work in the winter. Link to comment Share on other sites More sharing options...
KZJonny Posted January 11 Share Posted January 11 Wow! Good on them for fessing up and standing behind their warranty. Good to be able to share a positive result when going back to a shop. 1 Link to comment Share on other sites More sharing options...
Pleides Posted January 11 Share Posted January 11 Had nothing but good experiences myself with Safelite. I've been told they're kinda spendy but my local one does a good job. Best of luck getting everything redone. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12 Share Posted January 12 I had to have my wagon's roof painted years back for the same issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
