Gunvangelion Posted November 13, 2022 Share Posted November 13, 2022 Hello All, I recently join the forum to learn how to upgrade my 2011 Legacy 3.6R suspension. The car is just short of 130000km (~80000 miles). I removed the inner liners in the trunk area to inspect the rear suspension, but then I was shock to see on rust on the passenger side. I have attached photos, wonder if any one have experience this? I am aware the passenger side is the fuel tank side. Many thanks Link to comment Share on other sites More sharing options...
DugsSin Posted November 14, 2022 Share Posted November 14, 2022 That is a bit of corrosion I've got no clue why. Haven't seen that part of my Legacy more than a few times but seems to be free of rust at 119K miles there at least. Link to comment Share on other sites More sharing options...
creep_nu Posted November 14, 2022 Share Posted November 14, 2022 how's the underside of the car? could be something as simple as a leaky trunk seal getting the carpet wet, or it could be rust eating up from the bottom... 1 Link to comment Share on other sites More sharing options...
FLlegacy Posted November 15, 2022 Share Posted November 15, 2022 I would look for a bad seal on the trunk as @creep_nu mentioned. A bit of wire brushing and a rust converter should take care of that before it becomes too bad. 2 Link to comment Share on other sites More sharing options...
Gunvangelion Posted November 18, 2022 Author Share Posted November 18, 2022 Thank you all, I will try to take a deeper look this weekend and the advice above. Link to comment Share on other sites More sharing options...
Gunvangelion Posted November 21, 2022 Author Share Posted November 21, 2022 Hello All, Just a follow up, after removing the cover and checking the gasket, I think it is some surface rust only. will definitely clean it up before my suspension upgrade. another question, are 2 nuts suppose to be missing from the 4 bolts? This is at the center of the trunk, right behind the center rear passenger seat. Many thanks. Link to comment Share on other sites More sharing options...
DugsSin Posted November 21, 2022 Share Posted November 21, 2022 Interesting I guess only 1 nut is supposed to be missing. Don't even know what they are connected to but I will be adding one once size is determined. Link to comment Share on other sites More sharing options...
FLlegacy Posted November 21, 2022 Share Posted November 21, 2022 Now I'm curious about mine, lol. Link to comment Share on other sites More sharing options...
FLlegacy Posted November 21, 2022 Share Posted November 21, 2022 (edited) No nut November took on a new meaning, lol. I also found something is leaking in my trunk, so this was good timing. Edited November 28, 2022 by FLlegacy 1 Link to comment Share on other sites More sharing options...
DrD123 Posted November 22, 2022 Share Posted November 22, 2022 neither were installed in mine - wonder what they are for? Link to comment Share on other sites More sharing options...
DugsSin Posted November 22, 2022 Share Posted November 22, 2022 Given their central location I would say guide pins for differential or rear subframe member. I probably threw a nut on at some point 5~8 years ago. Will be putting winter tires on real soon and will take a look then cause the ole man ain't crawling under any car in 20 Degree weather. Link to comment Share on other sites More sharing options...
FLlegacy Posted November 22, 2022 Share Posted November 22, 2022 (edited) There is no bolts/pins going upward in that area for the rear subframe or diff. I would bet they are used during assembly or were a holdover from a different seating attachment point in a different model, outback or impreza possibly. Edited November 28, 2022 by FLlegacy Link to comment Share on other sites More sharing options...
motorbreath Posted November 23, 2022 Share Posted November 23, 2022 I'll take a look at mind this weekend, but don't remember any corrosion in that area when I replaced the rear suspension last year. Link to comment Share on other sites More sharing options...
