SIDrive Posted June 6, 2022 Share Posted June 6, 2022 Changing out the timing belt and noticed that no matter what I do the passenger side marks will not fully line up. Passenger top lines up but the passenger bottom and passenger upper to bottom pulleys are 1/2 tooth off. Crank and drivers side are spot on. Do not have the tensioner on yet. Am I over reacting and this is normal? Got 120,000 on the odometer. Way past time to change it. Factory belt and tensioner looked surprisingly good. Civilization has brought Evolution to a screeching halt 2007 Legacy GT auto 1989 Turbo Trans AM 1987 Buick Grand National 1983 DeLorean (Buick turbo transplant) Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 6, 2022 Share Posted June 6, 2022 You should be fine. I believe the intake AVCS causes this. If the teeth count is fine between the various marks, as per FSM, then it's all good. Link to comment Share on other sites More sharing options...
leetdrv Posted June 6, 2022 Share Posted June 6, 2022 its more important how the marks on the belt align to the cams. if the marks on the belt are not present you can count the teeth per FSM and make your own. Link to comment Share on other sites More sharing options...
SIDrive Posted June 6, 2022 Author Share Posted June 6, 2022 Can someone please point me to the FSM. Civilization has brought Evolution to a screeching halt 2007 Legacy GT auto 1989 Turbo Trans AM 1987 Buick Grand National 1983 DeLorean (Buick turbo transplant) Link to comment Share on other sites More sharing options...
silverton Posted June 6, 2022 Share Posted June 6, 2022 You should be fine, but won't hurt to double check. Link to comment Share on other sites More sharing options...
dgoodhue Posted June 7, 2022 Share Posted June 7, 2022 It looks like a tooth off to me. It isn't paint marks, it is the notches that have to line up. At least on my 5th Gen, if you are off by a tooth, it causes a error code and the check engine light will be illuminated. The 1st time I did my timing belt I made this mistake and I had to redo it. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted June 7, 2022 Share Posted June 7, 2022 Do you have pics of the crank and bank 2 marks? Link to comment Share on other sites More sharing options...
SIDrive Posted June 9, 2022 Author Share Posted June 9, 2022 Friend of mine stopped over and double checked the marks. Put her back together and she fired right up. Thanks everyone! Civilization has brought Evolution to a screeching halt 2007 Legacy GT auto 1989 Turbo Trans AM 1987 Buick Grand National 1983 DeLorean (Buick turbo transplant) Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 9, 2022 Share Posted June 9, 2022 Good job! Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted June 10, 2022 Share Posted June 10, 2022 The ONLY DEFINITIVE way to ensure a Subaru engine is in time is to physically count the teeth between the marks. Link to comment Share on other sites More sharing options...
SIDrive Posted June 10, 2022 Author Share Posted June 10, 2022 The ONLY DEFINITIVE way to ensure a Subaru engine is in time is to physically count the teeth between the marks. I did try that a few times. But was not confident I tabulated all the teeth. Overall the job was not the most difficult job I've done on cars it just requires extra care on one part - putting the belt back on. It was the job I was the most anxious on when cranking over the first time for sure! Civilization has brought Evolution to a screeching halt 2007 Legacy GT auto 1989 Turbo Trans AM 1987 Buick Grand National 1983 DeLorean (Buick turbo transplant) Link to comment Share on other sites More sharing options...
silverton Posted June 10, 2022 Share Posted June 10, 2022 I've done it so many times and still get anxious when I turn the key. Good job! Link to comment Share on other sites More sharing options...
