hamyscj Posted April 9, 2022 Share Posted April 9, 2022 Is it recommended to put any type of sealant on the head gasket? High tack or anything of the sort? New short block, OEM gaskets and rebuilt cylinder heads. Thanks! Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 9, 2022 Share Posted April 9, 2022 Some guys will apply copper spray. Most of the old guys in machine shops I've visited have recommended it, and one Subaru master tech has mentioned that he does it on some builds. I've seen it on a motor I pulled apart for someone as well. I've personally never coated a head gasket and haven't had an issue. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 9, 2022 Share Posted April 9, 2022 I've never used any in the five times I did it, doesn't mean I shouldn't have, but no issues from any of them. 1 Link to comment Share on other sites More sharing options...
hamyscj Posted April 13, 2022 Author Share Posted April 13, 2022 I got some copper spray and used it. [emoji2369] Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
hamyscj Posted April 13, 2022 Author Share Posted April 13, 2022 Thanks for the replies! Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
silverton Posted April 14, 2022 Share Posted April 14, 2022 I've done dozens of HG jobs, I used to use a copper spray but stopped. The best thing you can do for a HG is buy high quality MLS. 1 Link to comment Share on other sites More sharing options...
hamyscj Posted May 28, 2022 Author Share Posted May 28, 2022 I used OEM gaskets. Hopefully that's high enough quality...[emoji1696] Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 28, 2022 Share Posted May 28, 2022 I believe the OEM for turbo engines is a MLS, that's why they use them on NA motors when they replace HG's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
hamyscj Posted June 1, 2022 Author Share Posted June 1, 2022 Yep, they were. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
