BoozeRS05 Posted November 21, 2021 Share Posted November 21, 2021 I think you'd be fine with the same one for a stock size turbo, this is what I've got https://www.ptpturboblankets.com/collections/subaru-turbo-blankets/products/ptp-subaru-wrx-turbo-blanket-black EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
shralp Posted December 5, 2021 Author Share Posted December 5, 2021 Put the DEI heat shield on my Cobb DP today. Easy fitment and enough room from underneath to get it on without tearing anything apart. I like the 1/2" stand-off pretty much what I had in mind. If its all good and stays put I'll definitely put one on the track car as well this winter. Link to comment Share on other sites More sharing options...
whitexc Posted December 5, 2021 Share Posted December 5, 2021 Link? Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
JoeInOregon Posted December 5, 2021 Share Posted December 5, 2021 Put the DEI heat shield on my Cobb DP today. Easy fitment and enough room from underneath to get it on without tearing anything apart. I like the 1/2" stand-off pretty much what I had in mind. If its all good and stays put I'll definitely put one on the track car as well this winter.Ya looks slick , very nice Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
shralp Posted December 5, 2021 Author Share Posted December 5, 2021 They make a longer one as well this one is about 8” long. https://www.designengineering.com/stainless-steel-pipe-shield-4-5-x-8-5/ Link to comment Share on other sites More sharing options...
Infosecdad Posted December 5, 2021 Share Posted December 5, 2021 (edited) I just installed mine yesterday. I got the 6" x 1'. I have a lot less clearance as my HFC is right there at the axle. I had to pick up a larger clamp to make it around the cat for the middle clamp. Hopefully it's keeps from cooking my replacement axles, rather not do that again if I can help it. Edited December 5, 2021 by Infosecdad Link to comment Share on other sites More sharing options...
All_talk Posted December 6, 2021 Share Posted December 6, 2021 Put the DEI heat shield on my Cobb DP today. Easy fitment and enough room from underneath to get it on without tearing anything apart. I like the 1/2" stand-off pretty much what I had in mind. If its all good and stays put I'll definitely put one on the track car as well this winter. How far does it wrap around the pipe? With the 1/2” standoff could you get one between the pipe and the firewall? I put my Perrin pipe in last weekend and am a little concerned about how close the pipe gets to the firewall, I can just get my finger between at the closest point. Link to comment Share on other sites More sharing options...
shralp Posted December 6, 2021 Author Share Posted December 6, 2021 How far does it wrap around the pipe? With the 1/2” standoff could you get one between the pipe and the firewall? I put my Perrin pipe in last weekend and am a little concerned about how close the pipe gets to the firewall, I can just get my finger between at the closest point. I’d say about 60% coverage around my DP what you see in the pic is about it. I’d figure the standoff plus 1/4” to allow for the thickness of the shield. Also it’s quite flexible so if you need to doink a spot to get around or past something it’s easy to form. Link to comment Share on other sites More sharing options...
