DrD123 Posted July 18, 2021 Share Posted July 18, 2021 Well, I think we have a contender here... looks like VLEDS has released an LED bulb which instead of running full power all the time, the beams run at 800 lumens when they see DRL voltage (<10V) and full brightness (2500 lumens) when they see normal operating voltage... (this is different than the pulse-width modulation solution which has been available for a bit - these are specifically for constant voltage applications) Seriously considering this set... https://www.vleds.com/shop-application/application-high-beam/9005-low-voltage-daytime-running-light/micro-limited-9005-low-voltage-daytime-running-light.html 1 Link to comment Share on other sites More sharing options...
boxkita Posted July 18, 2021 Share Posted July 18, 2021 interesting. have you ever used there other products? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
DrD123 Posted July 19, 2021 Author Share Posted July 19, 2021 I have had their micro evolution extreme LEDs for my low beams for a little over a year and a half - they are great. They have said something like this (the DRL one) was coming for a while now, so I check every now and then. Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 19, 2021 Share Posted July 19, 2021 Everything VLEDs makes is top level. I'm hoping they have an option to add this module to people that already have their bulbs rather than having to buy whole new bulbs. I'm almost certain they did, just have to do a little digging. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
boxkita Posted July 19, 2021 Share Posted July 19, 2021 25yrs in business and based in bellingham? I might have run into them about a decade ago at a subie show. kind of curious if they can make some custom stuff, too. gb? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
testa422 Posted July 19, 2021 Share Posted July 19, 2021 interesting. have you ever used there other products? without question one of the best in the business Link to comment Share on other sites More sharing options...
pseudonym Posted July 20, 2021 Share Posted July 20, 2021 Everything VLEDs makes is top level. I'm hoping they have an option to add this module to people that already have their bulbs rather than having to buy whole new bulbs. I'm almost certain they did, just have to do a little digging. You're using their bulbs for high beams? Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 20, 2021 Share Posted July 20, 2021 You're using their bulbs for high beams? Have been running their Micro Limiteds in my high beams for about 2 years now. Yes, the DRL runs at full power, but I opted for their 3000K Ion Yellow ones so that it's not as obnoxious as 6000K in the daytime. They function awesome and the color is brilliant. I've also had my lights wrapped Lamin-X yellow this year as well, so the color is even more intense yellow but also a tad reduced brightness from prior as well. Still bright enough to change the color of nearby road signs to a yellowish hue in daytime, but also not blinding like an un-wrapped 6000K highbeam would be in the daylight. Fantastic product, doubly soo if they've finally sorted proper DRL function. 2019: 2021: 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
pseudonym Posted July 21, 2021 Share Posted July 21, 2021 Quick question for anyone who knows...am I correct in assuming that what was linked above is the same as the standard vled that most in this thread have used but with an attachment for the DRL? Meaning, if I bought a set of these, would I be able to attach the DRL attachment to my old vleds in order to have a newer set of vleds in the area that burns out the quickest? Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 21, 2021 Share Posted July 21, 2021 Quick question for anyone who knows...am I correct in assuming that what was linked above is the same as the standard vled that most in this thread have used but with an attachment for the DRL? Meaning, if I bought a set of these, would I be able to attach the DRL attachment to my old vleds in order to have a newer set of vleds in the area that burns out the quickest? That's what we're unsure of. To my knowledge, no one here has used a set of the DRL VLEDs, and some of the pictures make it appear as a plug and play module while others make it appear wired in-line, so it requires some research and clarification from VLED if it can be used on older bulbs. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
pseudonym Posted July 21, 2021 Share Posted July 21, 2021 Aren't they 2 different bulb types? Link to comment Share on other sites More sharing options...
testa422 Posted July 22, 2021 Share Posted July 22, 2021 (edited) Aren't they 2 different bulb types? no theyre the same...our DRL/high beam are 9005 and thats whats in the OP's link as well our low beams are a diff bulb type if thats what you mean. I also run vleds in my DRL like corey Edited July 22, 2021 by testa422 Link to comment Share on other sites More sharing options...
DrD123 Posted July 23, 2021 Author Share Posted July 23, 2021 I think the bulb/LED is the same, but from their website, for both the driver is hardwired to the bulb (no idea how easy it is to open/remove/replace) and the driver definitely looks different (and is labelled differently on their website) - they also some other stuff that comes with it - a second harness for each side, along with an anti-flicker/error cancelling resistor. The new ballast looks like you could disassemble it, but there could be adhesive in addition to the screws. regular version - https://www.vleds.com/shop-products/led-headlights/micro-limited-9005.html DRL version - https://www.vleds.com/shop-application/application-high-beam/9005-low-voltage-daytime-running-light/micro-limited-9005-low-voltage-daytime-running-light.html Link to comment Share on other sites More sharing options...
testa422 Posted July 23, 2021 Share Posted July 23, 2021 I think the bulb/LED is the same, but from their website, for both the driver is hardwired to the bulb (no idea how easy it is to open/remove/replace) and the driver definitely looks different (and is labelled differently on their website) - they also some other stuff that comes with it - a second harness for each side, along with an anti-flicker/error cancelling resistor. The new ballast looks like you could disassemble it, but there could be adhesive in addition to the screws. regular version - https://www.vleds.com/shop-products/led-headlights/micro-limited-9005.html DRL version - https://www.vleds.com/shop-application/application-high-beam/9005-low-voltage-daytime-running-light/micro-limited-9005-low-voltage-daytime-running-light.html good catch! Link to comment Share on other sites More sharing options...
DrD123 Posted August 4, 2021 Author Share Posted August 4, 2021 Well, I went ahead and got a set - need to install it, but for that need to sort where I want to put the driver and the resistor. For you guys that already are running the LEDs in the high beam, where did you put it - just zip tie it to the light harness? (for the lows, everything fit inside the headlight itself - obviously not something you can do for the highs/DRLs!) Link to comment Share on other sites More sharing options...
testa422 Posted August 4, 2021 Share Posted August 4, 2021 Well, I went ahead and got a set - need to install it, but for that need to sort where I want to put the driver and the resistor. For you guys that already are running the LEDs in the high beam, where did you put it - just zip tie it to the light harness? (for the lows, everything fit inside the headlight itself - obviously not something you can do for the highs/DRLs!) mine are just ziptied to the headlight harness yes Link to comment Share on other sites More sharing options...
DrD123 Posted August 7, 2021 Author Share Posted August 7, 2021 Ok sounds like a plan Another option I came across that is supposed to work for low voltage DRLs is the Morimoto 2stroke 3.0 - more expensive than the VLEDS, but doesn't have the separate resistor. I'm sort of curious what the external resistor does - I imagine it's used to step the voltage, but I am not sure why or what the morimoto does so that they don't need a separate power resistor (I am guessing based on the heat sink, vleds puts a bunch of current through it) Link to comment Share on other sites More sharing options...
KazeSupra Posted September 3, 2021 Share Posted September 3, 2021 (edited) I bought damn near the whole from setup from VLED (low beams, high beam/DRL, and fog lights). I wish I would’ve taken before pics, because it’s so dramatic when compared to the stock ones. I don’t think you’ll be disappointed. DRLs Lows only Lows + fogs Highs Sent from my iPhone using Tapatalk Edited September 3, 2021 by KazeSupra Link to comment Share on other sites More sharing options...
tony saurus Posted September 3, 2021 Share Posted September 3, 2021 DRLs Highs I hate to say it but the drl still looks like it will blind oncoming traffic. Maybe take a pic facing a wall so that we can see “the a$$h0l3 driving with the high beams on “factor Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KazeSupra Posted September 4, 2021 Share Posted September 4, 2021 I hate to say it but the drl still looks like it will blind oncoming traffic. Maybe take a pic facing a wall so that we can see “the a$$h0l3 driving with the high beams on “factor Sent from my iPhone using Tapatalk Yeah, I kind of noticed that when I posted the pics. I wonder if I had the control boxes on at the point when I took this? I'll try some more pics tonight and see if there's a difference. Link to comment Share on other sites More sharing options...
KazeSupra Posted September 6, 2021 Share Posted September 6, 2021 Alright, so here’s the “against the garage” pics. I took one of the controllers out so you can see the brights vs DRL mode. They’re pointed in the same direction, but it’s supposed to be 800 lumens with the controller in DRL mode, 2500 as high beams. DRL’s, without vs with the controller Lows + fogs Highs Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DrD123 Posted September 6, 2021 Author Share Posted September 6, 2021 So by controller, you mean the resistor, right? (I've had mine for a bit, but haven't gotten around to installing them yet) - where did you mount the resistors? I was looking at putting them on the brackets and have them attached to one of the headlight mounting bolts, but need to pull the bumper to get to it (or slot the bracket... I might do that) - weekends have been tied up for a bit, so just haven't had a chance! Link to comment Share on other sites More sharing options...
KazeSupra Posted September 7, 2021 Share Posted September 7, 2021 So by controller, you mean the resistor, right? (I've had mine for a bit, but haven't gotten around to installing them yet) - where did you mount the resistors? I was looking at putting them on the brackets and have them attached to one of the headlight mounting bolts, but need to pull the bumper to get to it (or slot the bracket... I might do that) - weekends have been tied up for a bit, so just haven't had a chance! Yeah, I guess I meant resister since that’s what they’re calling it. Passenger VLR6 for turn signal Passenger VLR4 for DRL Driver VLR4 for DRL Drivers VLR6 for turn signal Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
tony saurus Posted September 11, 2021 Share Posted September 11, 2021 DRL’s, without vs with the controller Highs I wouldn’t want to be driving in front of or towards you at night … just saying Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KazeSupra Posted September 17, 2021 Share Posted September 17, 2021 I’m sure you’d be fine. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
