Beamercub Posted July 1, 2021 Share Posted July 1, 2021 It was 102f outside. I was waiting in the car with a/c running and idling, and both eyesight and blindspot disabled along with CHECK ENGINE light.. I restarted car and got the same warning lights, car seemed to run fine, no misfires. I happend to have my OB2 reader in the car.. After connecting, 2 DTC codes; 0072/ P0072. After clearing the codes, warning lights went off.. I restarted no warning lights, I restarted again and no warning lights and no codes after running scan again. My car is black and it seems the temp is displayed 5-10 degrees warmer.. I had thought, the temp sensor got too hot and threw a code? Link to comment Share on other sites More sharing options...
Painless Posted July 1, 2021 Share Posted July 1, 2021 (edited) Could be just a one-off hiccup. If you want to dig deeper... Quick check through the manual points to the Ambient Sensor (or wiring) fault. Parsed-out the relevant data from my '16 which should apply to your vehicle. You may want to replace the Ambient Sensor (less than $15) as a precaution or at least verify the connector is properly seated and wiring looks ok. I do suggest removing the front bumper cover to make troubleshooting/replacement of the sensor easier.P0072 Code Troubleshooting.pdf Edited July 1, 2021 by Painless Additional info Link to comment Share on other sites More sharing options...
Beamercub Posted July 2, 2021 Author Share Posted July 2, 2021 Could be just a one-off hiccup. If you want to dig deeper... Quick check through the manual points to the Ambient Sensor (or wiring) fault. Parsed-out the relevant data from my '16 which should apply to your vehicle. You may want to replace the Ambient Sensor (less than $15) as a precaution or at least verify the connector is properly seated and wiring looks ok. I do suggest removing the front bumper cover to make troubleshooting/replacement of the sensor easier. Thank you for the visual.. Take me to your leader! Link to comment Share on other sites More sharing options...
