Painless Posted February 17, 2021 Share Posted February 17, 2021 2016 Subaru legacy 2.5i Premium While replacing my leaking front exhaust pipe/catalytic converter assembly (Service Program Bulletin WUJ-95) I also replaced both front and rear Oxygen Sensors. I'll post a separate thread (and replacement video) on the WUJ-95 (SOA Declined to cover it). I selected the Denso brand as they had good reviews with a reasonable price point and included small tubes of copper anti-seize. My warning is regarding the Fuel/Air Sensor P/N 234-9138. The wire length between the connector and sensor is about one inch too short preventing clip © from being installed properly. It is also bent hard at 180 degrees and tight. Contacting Denso regarding this issue resulted in less than acceptable response IMHO. All is operating normally, so, I'm leaving it as-is for now. Link to comment Share on other sites More sharing options...
apexi Posted February 17, 2021 Share Posted February 17, 2021 What did denso say? I wouldn't be comfortable with the hard turn. I'd probably slide the whole connector off the oem bracket I think it's mounted on (after disconnecting of course due to hard turn), let it float, and plug the plastic clip into the hole, maybe with a zip tie around it too to hold the clip in the hole. Link to comment Share on other sites More sharing options...
rhino6303 Posted February 18, 2021 Share Posted February 18, 2021 The clip you're pointing to should be able to slide along the wire cover. I'm not sure I see a problem if you slide the clip down the wire. Link to comment Share on other sites More sharing options...
Painless Posted February 18, 2021 Author Share Posted February 18, 2021 apexi: Advised Denso support of my issue and asked if they offered a patch cable or other suggestion for this. Was hoping that they would offer an acceptable replacement suggestion or patch cable. Only replied that they do not offer a patch cable. rhino6303: Thought about sliding the clip towards the sensor end (closer to the mount). Even just leaving it there and using a high temp zip-tie to the mount would have put additional tension on the wires. I'll look to see if I can flip the connector. Link to comment Share on other sites More sharing options...
Painless Posted February 21, 2021 Author Share Posted February 21, 2021 Here's a side-by side showing the issue. My solutions to follow (besides not getting Denso). I would not consider this to be "OEM replacement". Link to comment Share on other sites More sharing options...
Painless Posted February 21, 2021 Author Share Posted February 21, 2021 Ordered some assorted engine wire harness clips for a more permanent solution and will post once complete. Clip too tight to slide (and be of some use) so I removed it. Thanks for the suggestion apexi, loosened everything and it slid right off the blade. My temporary solution until then. Link to comment Share on other sites More sharing options...
